Anyone ever change the knives on a Wallenstein chipper?
   / Anyone ever change the knives on a Wallenstein chipper? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Anyone ever change or reverse the knives on a Wallenstein chipper? Was it easy or difficult? I have a BX-60 and would like to reverse the knives.
   / Anyone ever change the knives on a Wallenstein chipper? #2
I need to inspect and maybe flip the knives on my BX-42 soon, but am still running on the original edges after 8-9 years. I have heard it's not very complicated at all. Hopefully none of the bolts are stuck, as that would complicate it.
I think spacing could be an issue, meaning the distance between knife edge and cutting gap..
   / Anyone ever change the knives on a Wallenstein chipper? #4
Not that difficult.
make sure you have proper sized tools
i think they are metric.
small impact might help
   / Anyone ever change the knives on a Wallenstein chipper? #5
I have a Wallensten BX62S. A year or so ago I removed one knife blade. Just to see how it went. It was unbelievably easy. If your blade/anvil clearance is correct - it will be that same way when you rotate the knives or simply reinstall the blades without rotating.
Get them sharpened - you should check the knife/anvil clearances. The anvil may need adjustment.
An added note - any time you remove blades - be certain the blade and blade pocket are absolutely clean. No rust, dirt, smut, etc, etc. This will ensure a correct alignment.
   / Anyone ever change the knives on a Wallenstein chipper? #6
I used to have a BX62. I rotated and sharpened knifes a couple of times. Removing the knives is pretty simple as oosik said. Don't forget to rotate or sharpen the anvil - you have four edges on that. I used a worn hacksaw blade as a gage to set the knife/anvil clearance. Check anvil clearance on all four knifes as there is most likely some height variation and set the clearance using the tallest knife.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
44511 (A51692)
44511 (A51692)
2007 FELLA SM350 3 PT DISC MOWER (A52748)
2007 FELLA SM350 3...
