Anyone drilled a hole in the end of a pallet fork
   / Anyone drilled a hole in the end of a pallet fork #21
The tips are fairly thin so I can understand OSHAs concern, but then, they are OSHA. As was mentioned, moving a trailer with a ball on the tip is very little load. I seldom tip load anyway, most of my loads are fully on the forks up to the rack.
   / Anyone drilled a hole in the end of a pallet fork #23
I highly recommend against it. I did this on my old forks and the one with the hole and trailer ball over time got bent down. Not a lot but enough to make picking up pallets difficult. I never could get it straightened so I eventually got new forks and welded up a trailer mover that slips over both forks.
   / Anyone drilled a hole in the end of a pallet fork #24
My Titans did not. Must have been an option?
Ya, you generally have to order the forks separate from the frame. But you can get them with a hole in the end. I'm happy with mine, makes putting a ball in. I dont use my 3pt trailer mover anymore.
   / Anyone drilled a hole in the end of a pallet fork #25
We always had slip on extensions, and kept one with a ball in it. the extensions were not used that often. they were about a 6 in channel section with a hoop on the end that kept it from sliding off the butt end of the forks. a bent tip could have damaged a lot of product in the lumber yard. many bunks of trim and similar did not have very good sticks between them on the flatbeds delivering.
   / Anyone drilled a hole in the end of a pallet fork #26
You sure it was not that Teaxs heat that bent those tips? :D
   / Anyone drilled a hole in the end of a pallet fork #27
I was at a friends shop and saw a commercial fork that was bent back in a U about a foot back. I can't imagine the event that caused that. There must have been speed involved followed by rapid (probably totally unexpected) deceleration!
   / Anyone drilled a hole in the end of a pallet fork #28
I will try to remember to upload / post if I can a page from a fork manufacturers “Fork Facts”
   / Anyone drilled a hole in the end of a pallet fork #29
   / Anyone drilled a hole in the end of a pallet fork #30
If your load slips, put a piece of thin plywood between forks and load.
A former employer decided our forklift needed a fire extinguisher because all company vehicles needed a extinguisher. I mounted it with the supplied bracket by drilling two holes in the roll bar. The safety weeny inspected it and red tagged the lift since I modified a safety device. The idiot driver says "it must be OK because he drilled the forks too".
We sent a requisition to corporate for a new forklift because the roll cage was no longer available and the two items probably exceeded the cost of a new lift. We enjoyed a rental lift for two months until the safety idiot "reviewed safety policy" and decided no rules had been broken and we should use the old lift.
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
2020 FREIGHTLINER M2 106 BOX TRUCK (A56129)
2020 FREIGHTLINER...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
