Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil? #21
I wonder why they don't just dye the damn stuff at the factory, like ATF! It's so clear it's really hard to see.
I retired from Deere in '16. I remember corporate saying then that the new J20D coming would have a florescent dye in it that would glow under black light. A check station was going into all the assembly lines to look for leaks? Not sure if it happened though.
   / Anyone DIY dye their hydro oil? #22
Whatever type of red dye JD puts in from the factory sure smells good. Looks and smells like Grenadine. I wonder if the DIY dye Deere sells smells like the factory stuff?
If so, I might put some in just for the sensory experience during handling. :)
   / Anyone DIY dye their hydro oil? #25
I used half the JD dye bottle in my L3200 years ago & it worked well. I made sure to tell the guy I sold it to it wasn't ATF.
I went to use the last half of the bottle a while later, couple years maybe, & it was all dried out. I tossed it rather than try to scrape out the residue. I've been meaning to get more for my now 6 ish year old L4060, but never have.
   / Anyone DIY dye their hydro oil? #27
Would it hurt just to add some ATF? It is rather similar to hydraulic oil, or may well be a grade of hydraulic oil.
   / Anyone DIY dye their hydro oil? #28
I'm not sure what you're asking, but ... No, I'd not use ATF in either reconstitution or the dye, or just to color the hydraulic oil ...
I'm not an engineer, but I'm guessing there is a good reason they make both ATF and hydraulic fluid ...
What I don't understand is why the JD stuff dries out? Is it water based? If so it's surprising to me that you would intentionally add that to your hydraulic system! (Maybe it's not enough to matter?
   / Anyone DIY dye their hydro oil? #29
This is strange ... This is a screenshot of the above post ... Why does it need moderator approval?
Advertisers have forced the forum management was forced to add word filters that flag potential hot-topic posts. Since AT_ = Alcohol Tobacco F-arms, the software is going to flag your post... as it probably will mine.
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55851)
2022 Polaris...
2020 Deere 325G (A50123)
2020 Deere 325G...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
6-Band Wooden Barrel (A55853)
6-Band Wooden...
