Anyone DIY dye their hydro oil?
   / Anyone DIY dye their hydro oil? #1
WinterDeere
Super Star Member
Top Poster Of Month
Philadelphia
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
The hydro oil in my 2019 tractor remains so clear and clean, that I almost can't see it on the heavily-hashed dipstick on my 3033r. I see some run hydro oil (probaby ATF) with red dye in it, and I'm wondering, does anyone put some dye in their own hydro oil to make visibility at least a little better?
   / Anyone DIY dye their hydro oil? #2
My tractor has a dipstick, so I don't need to dye mine.
I've read here on TBN that John Deere sells a dye specifically for hydraulic systems.
   / Anyone DIY dye their hydro oil? #3
I use the JD dye. It works, turns the oil red. Does not take much. My L3600 has a sight glass, could not see the oil without the dye. Easy, just pour it in. Might mix with some of the oil to pour easier.
   / Anyone DIY dye their hydro oil? #4
Did you get that local or order it online? I have been wanting to add some to my tractors.
Mine has a dipstick, too! But both sides are cross-hatched, there's no smooth side for viewing the "wetted" line. Just about impossible to see the fluid without walking out to daylight with the dipstick in-hand.
   / Anyone DIY dye their hydro oil? #6
I ordered mine online, but you can find it locally also. I used more than was needed also - just use use a tad bit of it and it works fine.
   / Anyone DIY dye their hydro oil? #8
I got it online from a tractor store. It was silly expensive on Amazon. Little bit goes a long way. My Kubota has the impossible sight glass. It must be a Japanese thing. My Yamaha has one too :rolleyes:
   / Anyone DIY dye their hydro oil? #9
JD sells it, it's expensive per ml, you might get 2 fills out of it but they suggest it's for 5 gallons (if it's pasty or dried up, add hydraulic fluid and stir!) ... I bought mine from https://www.zoro.com/kingscote-dye-...red-4-oz-506250-r4/i/G5130815/#specifications (I bought some gloves also to bump total up to get "free shipping!")
Wear gloves, I recommend pouring/dripping it into the jug, then pouring into tractor ...
2 drops per gallon ...
Suihe 20'x20' Shelter (A53316)
Suihe 20'x20'...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
New/Unused 20ft Bi-Parting Iron Gate (A54865)
New/Unused 20ft...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
