Pat's Easy Change Anyone compare Pat's system to other Quick hitches
   / Anyone compare Pat's system to other Quick hitches #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Anyone compare Pat\'s system to other Quick hitches
Any one have experience with both, the Pat's system and other available quick hitches - Speeco, Landpride etc. etc.? How do they compare?
I don't plan on changing implements that often so I certainly don't mind getting off the tractor to do it. I just want to minimize the time it takes.
   / Anyone compare Pat's system to other Quick hitches #2
Re: Anyone compare Pat\'s system to other Quick hitches
Seems it would be comparing apples to bananas. Which landpride are you talking? Some have a top hook for the 3rd point, some only have lower hooks for two of the 3 points. Members like and find advantages to all. Pat's is a sponsor.
   / Anyone compare Pat's system to other Quick hitches #3
Apples to oranges....
A regular quick hitch is quicker/ less fuss to hook up, but it is less flexable in adapting to a wide range of implements. And much more work to remove for the non-adaptable implements.
Pat's is cheaper to buy, more flexable in fitting onto many different implements.
If all your implements are 100% compatable & you have a bum knee, the quick hitch is going to be your thing - easier.
If you live in the real world with different implement setups, a post hole digger or backhoe, are reasonably fit but want things easier than the regular 3pt (which is pretty easy already...) then Pat's seems a pretty good bang for the buck - or easier.
Different tools for a different kind of need, which is your need? /forums/images/graemlins/smile.gif
--->Paul
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
