Pat's Easy Change Anyone compare Pat's system to other Quick hitches
   / Anyone compare Pat's system to other Quick hitches #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Anyone compare Pat\'s system to other Quick hitches
Any one have experience with both, the Pat's system and other available quick hitches - Speeco, Landpride etc. etc.? How do they compare?
I don't plan on changing implements that often so I certainly don't mind getting off the tractor to do it. I just want to minimize the time it takes.
   / Anyone compare Pat's system to other Quick hitches #2
Re: Anyone compare Pat\'s system to other Quick hitches
Seems it would be comparing apples to bananas. Which landpride are you talking? Some have a top hook for the 3rd point, some only have lower hooks for two of the 3 points. Members like and find advantages to all. Pat's is a sponsor.
   / Anyone compare Pat's system to other Quick hitches #3
Apples to oranges....
A regular quick hitch is quicker/ less fuss to hook up, but it is less flexable in adapting to a wide range of implements. And much more work to remove for the non-adaptable implements.
Pat's is cheaper to buy, more flexable in fitting onto many different implements.
If all your implements are 100% compatable & you have a bum knee, the quick hitch is going to be your thing - easier.
If you live in the real world with different implement setups, a post hole digger or backhoe, are reasonably fit but want things easier than the regular 3pt (which is pretty easy already...) then Pat's seems a pretty good bang for the buck - or easier.
Different tools for a different kind of need, which is your need? /forums/images/graemlins/smile.gif
--->Paul
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
2020 DRAGON ESP...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
