anyone built a 3pt tree planter
/ anyone built a 3pt tree planter #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Hi all, I am in the process of building a tree planter for my CK20, has anyone built a 3PT planter that would work behind this tractor, the ones that are available for rent are too large, I have the wheels and coulter disc, lots of steel just need a design, any ideas would be appreciated
Laurence
/ anyone built a 3pt tree planter #4
Try " tree-toad" for some ideas ? I have used the hand-cart model and it worked great !
click here :
Tree Toad® Tree Transplanters
/ anyone built a 3pt tree planter #5
the one I built for CRP trees, was basically a single shank ripper with side shields on it, so one had time to put the tree in the slit created, and then the wheel packed the dirt back, the plastic jug was filled with some sand and worked for a spacer, to space the trees out. on very dry I had some trouble getting it to go deep enough, but on soils with moisture worked well,
/ anyone built a 3pt tree planter #6
here is a picture of the mulch layer for the trees.
the best way I found was to use marking paint to spray a spot on the mulch to show where the trees are, and cut after wards, (many people would be off up to a foot, and even it the mark is off, it usually was consistently off, to cut the "X" opening for the trees in the mulch, and at the same time of the pulling the tree though we would put the staples in.
/ anyone built a 3pt tree planter #7
I like the baby car seat! :D Get the whole family involved!
jb
/ anyone built a 3pt tree planter #8
It worked well and he was safe, and we knew where he was all the time and he wanted to be with his mom and dad who were helping me. that was a few years ago and to day he (my grandson) helped me plant some replants on one of the later plantings,
for the replants I used a 3" diameter fighting on a 7/16 rod and a 18 volt drill. it digs a nice hole and easy to plant and work with. Very similar to the "bulb planters" one some times sees.
/ anyone built a 3pt tree planter #9
What size trees and how many are you going to plant? Are you digging them out and relocating them, or buying them ready to plant?
I ask because for just a few trees, and in ones up to five gallon containers, I've had great success with my 12 inch auger. Not just trees, but for shrubs too.
Eddie
/ anyone built a 3pt tree planter #10
stooner said:
click here :
your expected to pound those in by hand?
oh lord, in the fall when the ground is rock hard in my area. thanks ill pass
(oh and how do you pull them out when your putting it in its new hole?)
/ anyone built a 3pt tree planter #11
"I have the wheels and coulter disc,"
I think Laurencen is talking about seedling transplanter like the whitfield.
Equipment
I have used a single row behind my tractor and seems a ck20 (Not Real familiar with this model) would lift and pull it. might need lots of front ballast.
/ anyone built a 3pt tree planter #12
If laurencen would re post, then people would know what he is looking for, or if he found it, if you notice its been two months since the first post,
and then may be some one could help him some more. or post more pictures of what has been built or some ideas, at lest.
my guess he has his problem solved in some form, 04-22-2008, 04:19 PM
http://www.tractorbynet.com/forums/build-yourself/120165-tree-planting.html
Hi All, sorry been busy working on the house, putting in a road, airstrip and trees, I wanted a quick way to plant seedlings around 8 inches, did get them in, made a knife on the 3pt, it sort of worked but could not get deep enough but the results I had got me thinking for next year,
I have a 60 inch spade for larger ones, lately me and the wife moved 60 scotch pines ranging from 10 foot to 18 feet tall a distance of 10 miles, took a wile. we made the mistake of tilling the area before we planted, now we have I assume alfalfa rampent,
We purchased a rake for the CK20, any tips how to get it to rake stones, it works but after a wile it plugs up, if we angle it enough to move them sideways the next pass is too much pull on the side, will have to take a few pictures next week when we are out there
/ anyone built a 3pt tree planter #14
The alfalfa is your friend. Its deep diving roots will bring up minerals from deep in the soil, open avenues for the tree roots to dive into, and aid in drainage.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2007 Amkus Rescue System (A59228)
2007 Amkus Rescue...
2018 23ft. Carolina Skiff Ultra Elite Boat with 24ft. T/A Boat Trailer (A59231)
2018 23ft...
