Anybody Spray Apple Trees?
   / Anybody Spray Apple Trees? #1
HillStreet
Veteran Member
Maine
Kubota B2650HST. Kubota Z125S
I bought 8 acres of a former orchard and built a house. I am in the process of restoring the orchard, which had been idle for 15 years. I severely pruned about 25 trees that are closest to the house. I began spraying them this year with dormant oil, fruit tree spray, and captan. The trees are now in petal fall and it seems the trees are budding nicely. I should know in a few weeks if the apples will be okay. The severe pruning did not seem to harm the trees. I do not know if it is more important to prune, or to spray. I can tweak the pruning next year.
I have also removed about 25 trees with the stumps. I replanted the area with 60 dwarf apple trees this spring and most seem to be coming along just fine.
I need to improve my skills in identifying herbicide issues or insect issues. I can spray to eliminate any and all problems but that may just spray chemicals that I don稚 need to be spraying. The university extension is very helpful by publishing bugs and diseases that have been found in the area, but that doesn稚 mean I have them.
What do you folks do with your fruit trees. Thank You.
   / Anybody Spray Apple Trees? #2
I had 18 semi-dwarf apple trees - about six varieties. They were all planted - when we moved here in '82. I took the last of them out two days ago. I sprayed for aphids and leaf curl( I think that's what it was). Didn't have to spray every year. Biggest problem, by FAR, pocket gophers. It took 46 plantings to finally get 18 to survive pocket gophers. In the day I would dig a huge hole - line it with two inches of broken glass - then good soil and the young tree. I don't know if it was prior to "gopher cages" or they just hadn't reached our area yet. What a PITA - we would get a normal wind out of the SW and three or four of our young trees would lean and fall down. Root eaten clean - back to the main trunk.
I'm cleaning out the orchard area and going to replant two early transparent apple trees. I will be using the gopher cages and if they get big enough ( gophers won't bother after about the fourth year ) two will be more than enough apples for just me.
   / Anybody Spray Apple Trees? #3
If you are already following the Extension guidelines, that is the best advice I could give you.
As to whether or not to treat, you could use their bug/disease data to then do a google search on each bug or issue, how to identify, etc. and then apply as needed. If you are near any other growers, they may appreciate that you are treating your trees to limit carryover of issues into their operation.
I only have a handful of trees, but growing up Dad had 50 to 60. He was pretty religious about following the extension guidelines for both pest management and applying nutrients, once he started doing that he went from a few buggy misshapen apples to a very nice harvest.
Right now all we are doing is applying bt to try and limit gypsy moth caterpillars. They hit us hard the last couple of years. In general, we aren't doing a lot to manage the trees so mostly what we are getting is, you guessed it, a few buggy misshapen apples...when the deer don't get them all.
   / Anybody Spray Apple Trees? #4
Ha, ha - - that the reason I will be planting two new apple trees. One for the deer and raccoons, the other, hopefully, for me.
   / Anybody Spray Apple Trees? #5
I missed the dormant oil spray on mine this year, mind was somewhere else I guess. I have sprayed once already for insect and disease. I have a few of each apple, peach, pear and plum.
I give them a light pruning every winter and a layer of mulch out to the drip line. Fertilize during early bloom.
My biggest problem is the bucks wanting to rub them in the fall. Gonna have to run the electric fence around the orchard. Keeps them out of the garden.
I will definitely spray because there is no such thing as a good apple without spray. I am encouraged by the buds this year (first I ever sprayed) so I will watch them closely. I will have to deal with mice and deer but it is the apple crop I just want to see grow. This was a large apple orchard that thrived for many decades.
   / Anybody Spray Apple Trees? #7
I must spay and neuter mine, as they never have any offspring.....
   / Anybody Spray Apple Trees? #8
You may think that you will tweak your pruning next year. The truth however, is that you will find yourself cutting more out next year than you did this year. A healthy apple tree will put out water suckers like crazy, once they are't supporting all of those extra limbs.
I took on pruning an orchard in 2005 which I had done years before in 1984, and made pretty good weekend money. Like a dunderhead I didn't look at it, and told him that I would keep it up as long as he wanted it done. Then I went out and started working in it. It's amazing how much they had grown. I don't even know how he sprayed, the rows were all intertwined. Yet I couldn't just cut them back or all that he would have is stubs.
I worked on it every spring for 13 years. I gradually got growth coming in from the center, so that I could cut the outside limbs back. One year I went through with a chainsaw and cut the tops out of them; anything I couldn't reach from my 14' ladder got cut.
I hate running chainsaws from a ladder; I never feel safe.
13 years I worked on them, and never could get a tree done in less than 1 1/2 hours; often it took 2 1/2 to 3. When I started he had over 70 trees, but he gradually cut them back to about 40. I was burning up two weeks vacation every spring, and not getting my own projects done. I also realized that I'm not 20 any more; I don't move as fast, or take the chances I used to when the ground was softer and gravity wasn't as strong.
This year I told him that I might not have time to do them, and encouraged him to find someone else now that I had them back to a reasonable size; but it would be pretty hard to find someone who would work for what I did them for- 17 $/tree. I would work most of the day just to pay for my 100 mile round trip drive. I feel guilty because I left him hanging, but I'm finally getting caught up on my own springtime projects, my fruit trees got into the ground before they died, and I might even have a decent garden for the first time in years.
Jstpssng, I do know about the water spouts as I had many this year from a few trees I did last year. That is not a problem as they are small. I will be trying to shape them next dormant season so that they are airy and will grow good fruit. Do you suppose the drop will grow this year after pruning and spraying? I hope so.
   / Anybody Spray Apple Trees? #10
I cut mine way back last yr, and had good bloom this yr. However i have lots of watersprouts that i should have removed and didnt.
   / Anybody Spray Apple Trees? #11
I had rotten luck with apple trees here but had peach and plum and got stuff from them until Brown Rot hit.
Best protection for any fruit tree is to spray a couple times during the dormant season with dormant oil. As a young chemical engineer, I once designed a distillation unit to manufacture it. It's just a very narrow cut of light diesel. It suffocates the bugs in their winter hibernation.
Next best thing for any pitted fruit would be to spray a solution of 9 to 10/1 water/milk (any milk) around bud break time as protection against brown rot.
Otherwise, I wouldn't do any more sprays unless you want your fruit to be equally as poisonous as what you buy in the store. The typical in-store (non organic) stuff has been sprayed to high heaven. Yeah, tastes good and looks good and probably isn't bad for you, particularly if you peal your apple first. Cannot see doing it in one's own orchard.
The dormant oil will get most bugs, and (hopefully) the milk solution may stop brown rot. Next stop: kill a couple squirrels every year to keep them from robbing you of your fruit.
Ralph
   / Anybody Spray Apple Trees? #12
One of the most important things about orchards is sanitation. The moths that cause worms in apples are not good flyers. The worms burrow out of the apple and pupate in the grass under the tree, then fly up to plant eggs in the next year's blossoms. It's common to remove all grass under fruit trees, with very shallow (1" deep) tillage. Spraying the ground rather than the trees, or spreading malathion dust/granules under the trees during blossom season is popular.
Pruning is necessary to get good production out of an orchard, but the older the tree the more work it is. Fruit trees are often replaced every 20 years or so because the labor to keep an old tree in production becomes prohibitive.
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2007 Western Star 4900 (A56438)
2007 Western Star...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
