Front-End Loader any use for a Boom pole? after having a FEL.
   / any use for a Boom pole? after having a FEL. #42
I have a 3 pt. plate for my bobcat and 3 pt.boom which I got whit my 9N, it's very handy ...
In one of the picture I replace the pump for my water well , in the other two I am installing the main been for the floor .
   / any use for a Boom pole? after having a FEL. #43
Depends on what ya need to lift. The 3pt will lift more weight than the loader but not as high. The loader will lift higher but not as much weight. I made this for my bucket for picking up stuff.
M.D.
   / any use for a Boom pole? after having a FEL. #44
when dad had his 3130 with loader he i used rhw boom pole on the back to lift the spike harrow when we pulled it.
   / any use for a Boom pole? after having a FEL. #45
My most recent boom pole use was lifting the top for the welding table I'm building.
   / any use for a Boom pole? after having a FEL. #46
That's a project , when you start the table make pictures .
I wish you easy weldsssss
   / any use for a Boom pole? after having a FEL. #47
I used my boom pole to take my boxblade out of the back of my van. When I bought it it took four men to load it and I removed it myself with the boom pole. With tight quarters I could not have gotted it out with FEL and it was too heavy to remove manually by myself. Worked very slick.
Hillman:)
   / any use for a Boom pole? after having a FEL. #48
I've used a boom pole a couple times when I needed more lift than my loader could provide, .. though for light objects.. etc.
soundguy
   / any use for a Boom pole? after having a FEL. #49
I use my 3 point pole to lift trees after I cut them down. Makes it easier and faster to cut to fire wood length than working on the ground.
   / any use for a Boom pole? after having a FEL. #50
I use a choker chain hitched to the drawbar to pull and the boom pole with tongs to lift:
Works great.
-Jim
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
