any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #291
Sounds like a good deal.
Have you measured the actual difference in circumference between the old and new tires?
You must have a late model 325D to have the two-way clutch. Let us know how it works with the new tires.
   / any toro groundsmaster fans on here? #292
Drove it on concrete to check for binding traction, with no apparent issues. I have 3/8in clearance on the left side fender (in front of tool box), and about the same to the inside (outside of frame).
Quick question... I just replace the trans (whole assembly), and I'm having one heck of a time bleeding the steering and lift circuits. About a half gallon of fluid and some bubbles later, still no power steering and lift. Both worked fine before I replaced the trans. Any advice?
   / any toro groundsmaster fans on here? #293
No circumference measurement, but here are some pics (the scrub marks are from having to move it with the old flat tires, not from the new ones):
Mine is a '98 model. They listed an option for 10.50 width tires in the manual and optional wheels (12x10, I think)... but mine had the standard 12×8.
   / any toro groundsmaster fans on here? #294
Those tires look good on there - but maybe a little tight?
   / any toro groundsmaster fans on here? #295
Maybe...
I wouldn't limp them around on low pressure.
I tried them out on a wet incline and a soggy runoff area. Great traction and flotation.
Only issues I have experienced are turf damage when turning sharp from sidehill to uphill climb (easy enough to avoid), and a somewhat reduced ride quality. My old turf tires had some give, but were old and worn out. With the weight of my flail deck and the stiffer tires, downhill on rough grade gets a bit jerky on fore/aft weight transfer... not enough to lift the rears, but enough to make my worn out Grammar seat uncomfortable after 6 or 7 acres of hillside
   / any toro groundsmaster fans on here? #296
Maybe...
Roughness - another reason to run them flatter. What you are feeling is them going up on a cleat and then off.
   / any toro groundsmaster fans on here? #297
EBAY PUMP.jpgFinally got the Hydro problem on my 325D fixed. The pump was getting too weak to lift deck and hard to steer.
Instead of taking it out over the winter, bought a EBay pump for a spare, $430. It looked so good ,decided to
just try it. Just primed it with clean oil, and swapped. It works great ,now lifts deck even at lowest throttle, and
steers soo much easier. Happy Mowing
   / any toro groundsmaster fans on here? #298
Not really. On the flats, they're fine. Only on rough terrain headed downhill do I feel any difference. When I say "rough", I mean steeply sloped pasture with drain lines and cow paths. On the normal bumpy (not maintained "turf"... just normal field mowing) they're great.
   / any toro groundsmaster fans on here? #299
View attachment 552405Finally got the Hydro problem on my 325D fixed. The pump was getting too weak to lift deck and hard to steer.
Nice catch Carl. A working transmission with a good charge pump will usually fetch around the $700 mark. A refurb will run around $1,600. If you're lucky enough to find a new unit (I was told by Sauer-Sundstrand they don't make them anymore) they're about $2,000+.
   / any toro groundsmaster fans on here? #300
Thought I'd share my latest find, with you guys...
My replacement flail deck!
That's not water shining... It's OEM paint!... and she's dirty, at that!
I still have two 72" recycler decks for sale, my old flail deck, and a 2wd 328D with 2nd gen Cozy Cab (wider model) with working fan and full light package, auxiliary front hydraulics, and 3 rear suitcase weights.
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55788)
2009 Peterbilt 384...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2018 Ford Fusion Sedan (A55758)
2018 Ford Fusion...
