Any suggestions on a camera?
/ Any suggestions on a camera? #21
Ok here's the deal. I have some motorcycle parts that I want to put on Craig's List, so I take the pictures and remove the USB card from the camera, put it in the computer and send the pictures along with the ad. Don't know how to do that with the cell phone pictures. So there you have it, don't need a high dollar camera. Thanks. RRM
You simply plug the cellphone into computer, or use an app like photo transfer. Dont need anything special.
/ Any suggestions on a camera? #22
Some newer android phones are a bit tricky to transfer images. When you plug in the USB cable, phone to desktop, swip down from the upper left hand corner. The phone will say charging with USB cable. Tap for more options. Tap on this message and you get USB options. Turn on File transfer. It will ask this every time. Now the computer can "see" the phone as an external drive and you can copy save the image folders from phone to computer.
As to cameras, The Nikon Coolpix L800 series are what we use mostly. We like these because they take rechargeable AA Batteries and used, they are under $40. The weakness to these, is how badly the Battery and SD card hatch/cover is designed. They are very easy to break if one is not careful about how these hatches work, and near impossible to fix if you break any of the latching tabs.
/ Any suggestions on a camera? #23
All the kids would shoot a picture on their phone and upload directly from their phone.
/ Any suggestions on a camera? #24
I have a Cannon Rebel. It looks like one can be had for u deer $500 now. If you want higher quality pictures and the ability to zoom in better, it’s a good choice.
From what you describe I also think a cell phone camera is a good choice. I have an iPhone 12 that takes good pictures. Once you figure out how to download, you will find it simple. For example my iPhone and IPad are linked to the same account and if I take a picture on my phone it shows up on my iPad a few minutes later. I also sprung for additional memory with my phone company for backup for $0.99 a month so all my photos are backed up.
/ Any suggestions on a camera? #25
So that's why the colors are awful, can't see the item for sale on FB for the all the contrast and they should have been cropped. People really should edit them all. o_O
/ Any suggestions on a camera? #26
Inadequate lighting will wreck color rendition and contrast on most sensors. If the photo is correctly exposed with adequate lighting, the color rendition should be just about correct for most people.
/ Any suggestions on a camera? #27
I really like the CL app.
Post straight from your phone.
/ Any suggestions on a camera? #28
Wife has an I-phone and it's a real PITA to transfer pictures from it to a PC. Some will transfer, some for whatever reason won't, and it seems to go stupid after a certain number of transfers. Got to disconnect the phone, re-connect the phone, sign back into the phone and it'll let you do a few more before it hangs up again. I think there were a few steps you had to go thru with the PC too to get to the screen where you could see the pictures. It certainly wasn't as straightforward as with my Canon Powershot.
This is with a Win10 PC, might work better with a mac, but we don't have one.
/ Any suggestions on a camera? #29
For some reason, my current Android phone won't transfer via USB, even after making the necessary settings. I use a free app called Send Anywhere which transfers over my home wifi from my phone to the computer. Works very well.
/ Any suggestions on a camera? #30
If I need one or two pics from my phone I usually transfer to Google drive, no bother with cables. Every couple months I cable up and dump all my pictures to my computer but that takes a long time.
/ Any suggestions on a camera? #31
Here is a photo taken on a very dated Lumix camera today. Its a fancy pocket camera. At home it was was DLed via SD card then cropped, color adjusted, down sized and contrast adjusted etc, etc. I am a amateur. She likes to jump off the top of logs.
/ Any suggestions on a camera? #32
Very dated Nikon D70s plus not outdated Nikon 35mm f1.8 DX lens. No editing except to decrease the size to post here. That camera plus the lens and the compact flash card it uses plus a card reader can be bought for under $250 used. There are lots of low mileage cameras to be found inexpensively because they aren't the latest and greatest. Some people never invest the time and discipline to learn how to shoot. They keep buying new cameras hoping a new camera will give them the results they want instead of first learning how to shoot with what they have. This is partly why there are so many used cameras for sale at inexpensive prices.
Unlike a completely automatic point and shoot, a Nikon D70s has full control over ISO, shutter speed, an aperture. This means you aren't dependent on the camera to make the camera settings so you can set shutter speed high enough to avoid motion blur, set aperture deep enough for sharpness, and control ISO appropriately for the shutter speed and aperture.
It's not the camera I'd use for shooting basketball or for anything in low light situations. But its perfectly fine for photographing something outdoors in good light just to post to CL.
A cell phone or tablet might work, too
sample.jpg.
/ Any suggestions on a camera? #33
My old camera finally gave up the ghost, so I'm in the market for a replacement. Does anyone make a good one for under $250? I went online to search and about fell over, there are some in the $2000 range. Don't need the smoke and mirrors, just take good pictures and maybe a close up feature. Thanks. RRM
What kind of camera did you have that gave up the ghost? This will give us a good idea what you're looking for, and what your used to.
Cellphone cameras are ok in some instances. They take better pics than old digital cameras of years ago. However, they have woeful limitations for real photography. I do use my phone for lots of pics because I always have it with me.
My first digital camera was a Sony pocket camera. It sucked. My second was a Canon point and shoot with a big zoom. It was better.
Then a Canon 6D than a7DII now an EOS R5. All of these options are way over your price range. Until I know what you had, I can't offer much advise.
Dave
/ Any suggestions on a camera? #34
Dad gave me his old D70 for my birthday (many years ago). He had upgraded to a newer better Nikon.
A few years ago we bought a simpler Nikon B500. It takes better pictures than the D70, but doesn't have the ability to swap lenses and that sort of thing. I miss the old days of real photography. I took a class in HS using real film and doing our own darkroom work.
/ Any suggestions on a camera? #35
I too am looking for a decent compact camera, $500 range ... Nikon or Canon, maybe Kodak ?
- it needs to fit into my jacket pocket, as I don't want to carry it
- not too tiny, i have large mitts :)
- digital
- zoom lens
- don't need or want extra lens, pieces ... my daughter is a photographer
(I fall down regularly, and this is why I also don't have a cell phone to carry ... that would cost me a lot) - my little flip phone is Pay As You Go, no data, adequate for cell phone, but the camera is lousy
the Camera needs to be something convenient to take with me or have in the car ... i go to car shows, agriculture events, see family and friends
example ...
/ Any suggestions on a camera? #36
There are legitimate reasons to upgrade. If someone wants to photograph dogs and cats, the automatic eye detection autofocus in the Z50 is a significant upgrade along with the improved sensor and the rear display that can show you what your picture is going to look like before you snap the shutter. It will also fit into a large coat pocket with the kit lens unlike many DSLRs.
If the budget is really $250, I'm just saying an older model DSLR is suitable for making pictures for CL. You can buy several older lens at affordable prices that still make good pictures if you shop carefully and tailor your lens purchase decisions to what you intend to shoot.
d70s +55-200 kit lens no editing except to convert to jpg to upload.
/ Any suggestions on a camera? #37
- digital
- zoom lens
This one is not exactly pocket sized, but maybe a coat pocket?
/ Any suggestions on a camera? #38
Might be just above your price range (esp in Canada) but I think the Canon G7 series is a very good choice in high end non-interchangeable lens cameras.
/ Any suggestions on a camera? #39
Torvy - yes, something like that.... generally a vest pocket, coat pocket, cargo pants ... I still need ball room
/ Any suggestions on a camera? #40
B500 Uses AA batteries, no dedicated ISO settings button nor any shutter or aperture dials that I see.
What tends to happen is that when point and shoot cameras encounter low light, they automatically drop the shutter speed to compensate resulting in a blurry picture or the colors get mushy.
Fixed lens limits your choices of lens for different situations. 1080p not 4k video. 1/2.3 sensor with 16 MP resolution instead of a larger APSC sensor which will do better in low light. Has a 3 inch LCD rear display, but they don't list the resolution and I doubt it's a touch screen.
Z50 is more money, but has a rechargeable battery, dedicated ISO control, front and rear command dials to control aperture and shutter, touch screen rear display (excellent BTW), ASPC sensor, accepts other Z lenses, 4k video is awesome, has animal eye detect AF, 20 MP sensor.
I'd suggest comparing them in the store, but I wouldn't be surprised if the Z50 is more compact with the lens closed.
edit: I probably should explain more. A mirrorless camera like the Z50 will display what the camera sees in real time either in the viewfinder or the rear LCD screen. Having two command dials to instantly change shutter speed and aperture means you can control your settings and instantly check the picture you are about to shoot and make adjustments to get the exposure you are looking for. The rear display on the Z50 is also a touch screen display so you can easily scroll and zoom the picture you just made to check to see if the picture is really in focus. The screen resolution is sufficiently detailed that you really can see if you got the shot or if you need to reshoot something.
That's part of the reason why the B500 is $350-400 and why the Z50 is more money.
8' DISC HARROW (A60430)
8' DISC HARROW...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
MARKER LIGHTS (A64276)
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2015 Ford Mustang Convertible Coupe (A61574)
2015 Ford Mustang...
