Any suggestions how to get this tree on the ground safely?
   / Any suggestions how to get this tree on the ground safely? #51
Can you drop another tree on the mess? Hoping that will be enough to get everything to the ground. I've seen it work, sometimes it takes two or three tries.....
   / Any suggestions how to get this tree on the ground safely? #52
The split trunk looks just strong enough that I suspect dropping more trees might make a bigger situation.
   / Any suggestions how to get this tree on the ground safely? #53
but just think of the eventual bonfire to clean up the mess after dropping a few more on there! that's like a 70' tall teepee of kindling!
   / Any suggestions how to get this tree on the ground safely? #54
Just put an old tire right here filled with used motor oil and some gas. Light 'er up and watch the fun.
I like this solution, tho I think just to use a wood fire. In burn season. Even if burning up the base does not cause the tree to fall, you can detach the base this way, then use the tractor to pull it until it does.
This assumes you are not at high risk of starting a forest fire.
I do a lot of cable/snatch block tree work on my property.
   / Any suggestions how to get this tree on the ground safely? #55
That reminds me of a fireworks contest we had between my buddies father in law and his sister in law. They had lake houses on opposite sides of the cove.
Whomever had the best display got a bottle of wine and bragging rights.
They sent off this pretty spectacular grand finale.
We were down to one measly little bottle rocket and weren't about to admit defeat.
Buddy lit the bottle rocket and it flew into a dead pine tree
That old pine tree went up in spectacular fashion.
After we grabbed garden hoses from some neighbors and managed to keep the fire from spreading we saw a light flash a few times with them signaling defeat
A few minutes later we heard a boat start up and they came over with the bottle of wine
   / Any suggestions how to get this tree on the ground safely? #56
A big dozer could have it on the ground in a hour by digging out around the roots.
I have a large rotten tree that snapped off about 40' up, came down and stuck in a fork, then teeter tottered heavy end down right over our walking trail about 8' off the ground. Like the suggestions here, I left it alone and waited for Mother Nature to make a move. After almost a year, we had some high winds w/T-storms last week. Walking the dogs I found that another tree, well over 100' tall had blown over at the root ball. You betcha...., it came down right over that fork and hung up on it just like the O/P's tree, forcing the teeter totter section 30' up off the ground now.......what are the odds? And what a mess!
Any chance of getting a bucket truck or lift near the top to release it from the other trees?
They could get to part of the crown to free up one of the larger branches, but there are 2-3 others I don't think they could safely get to (I imagine depending how the tree rotated as it freed up, anyone in the bucket would be at risk).
I don't like wasting people's time, but I'd be curious to have an arborist out to quote taking it down just to hear their thoughts/approach. But I'm guessing the quote will be higher than its worth to us.
   / Any suggestions how to get this tree on the ground safely? #58
Sometimes the guys who come out to give quotes are the owners or salesmen for their company, but they have employees are the ones who'll do the actual work. So they may or may not say much more than what their bid will be.
If there is room to get a lift truck, some would start cutting from the top to disentangle the trees so the damaged tree will fall. Or it could be a combined approach. They might cut some of the tangles loose, but not enough for the tree to actually fall until they rope it with a compact track loader and can then pull it down from a safe distance.
   / Any suggestions how to get this tree on the ground safely? #59
Here's the solution. A simple motor drive reciprocating mechanism with a bow saw on it. Start it...walk away. 100% safe!
   / Any suggestions how to get this tree on the ground safely? #60
Very hard to make a conclusion from the pictures... to go in and assess it myself and cutting it, is different then telling someone how to from a picture.
Also seem like term widow maker gets thrown around to every crooked tree (most of them are not) ... not saying this one is not one of them but in my opinion it is not. Where I am from the term widow maker get used for unpredictable tree like dry/rotten tree, type of tree that prematurely break in half while fallen . If you can likely predict what it will do it is not a widow maker, it doesn't mean it is not dangerous it only means you can adjust yourself in consequence and mitigate the hazard.
2844 (A58376)
2844 (A58376)
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
Cushman Electric Cart (A55851)
Cushman Electric...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
