Any problem with bulk diesel tank in the barn/shop?
   / Any problem with bulk diesel tank in the barn/shop? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
23 years ago I had a 150 gallon bulk diesel tank in the barn on rollers because I was painting it. I went to work and the bulk driver filled it there. It's still there and a 90 gallon tank on rollers next to it. Concrete floor; nice new pole barn and 42x60x 14'H.
I never saw a problem since only a few lights, not much going on and power off most of the time. Now, however, I plan to insulate the barn and put up a propane heater. Maybe keep it 55' away--but still inside the barn--- since I only want the barn at 50 degrees most of the time.
Any problems with this?
   / Any problem with bulk diesel tank in the barn/shop? #2
Put up a small lean too, for shade and rain protection.
   / Any problem with bulk diesel tank in the barn/shop? #3
I never saw a problem since only a few lights, not much going on and power off most of the time. Now, however, I plan to insulate the barn and put up a propane heater. Maybe keep it 55' away since I only want the barn at 50 degrees most of the time.
Diesel hates 3 things, HEAT, water and microbes. Avoid all 3 and you have great storage.
   / Any problem with bulk diesel tank in the barn/shop? #4
My diesel and gas are stored in one walled off bay of my carport. Up off the ground on pallets. It's not heated but reaches the ambient temps - both summer and winter. Never had a problem.
My ATV is stored in this bay also. Starting the ATV has never been a problem either. Been this way for 40+ years.
Oops--I meant to leave the tanks inside the barn with a propane furnace off in the far corner of the barn. Tanks stay in barn and furnace added.
This way my fuel is clean, dry and no problems.
   / Any problem with bulk diesel tank in the barn/shop? #6
A ceiling mounted Furnace wont cause explosion if thats what your worried about. Fumes from fuel stay low…aprox 12-18” from ground.
   / Any problem with bulk diesel tank in the barn/shop? #7
I personally wouldn't worry about storing diesel in a heated barn. #2 diesel has a flash point of around 125 degrees F.
I store 108 gallons of diesel in my pole barn, but keep the gasoline in a small shed.
Yeah, I keep gas out in a shed. Too big of a risk.
   / Any problem with bulk diesel tank in the barn/shop? #9
@sixdogs
While diesel's flashpoint isn't that high, I would put a large diesel tank behind a firewall just to lower the chance of a small fire becoming catastrophic. It doesn't take a lot of fire resistant plywood or plasterboard to make a nice fire resistant wall and ceiling.
Most oil tanks for furnaces are enclosed for fire resistance as well.
All the best,
Peter
@sixdogs
All the best,
Peter
That makes sense.
2017 FORD E350 16FT BOX TRUCK (A45678)
2017 FORD E350...
2014 Ford F-350 Crane Service Truck (A48081)
2014 Ford F-350...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2007 Toyota Camry Hybrid Sedan (A46684)
2007 Toyota Camry...
2013 ISUZU NQR 12FT DUMP TRUCK (A45679)
2013 ISUZU NQR...
Diesel Pump , Hose and Handle (A46684)
Diesel Pump , Hose...
