Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota?
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Is there any problem to run Rotella T6, 5W40 synthetic in my Grasshopper mower that has a 25HP Kubota diesel? I can't imagine any issue but the Kubota engine booklet with it calls for 10W30, 10W40 or 15W40. So, is 5W40 oil OK to use?
Thank you in advance.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #2
I see no problem. I run that in my Branson year round.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #3
Well I am running T-6 in their gas engines (Kawasaki z 900RS and JD X-500 lawn tractor and they seem to like it just fine.
My guess is the only thing you will notice is if starting during cold weather, by having a faster cranking speed and faster build of oil pressure since it flows better cold than 15W - 40. quicker oiling in cold reduces dry start up wear imo.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #4
I run T6 5w40 in my RTV and tractor because I use both of these in the cold depths of winter. Sure allows the engine to spin faster on those cold mornings.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #5
Should be able to run that just fine. I run T6 15w 40 in my gas mowers and 5w 40 in anything that I'm starting in the winter (tractors). It was hit or miss on the store shelves for a while. I'm starting to see it in stock again.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #6
T6 is nice stuff and you can run it in alot of different stuff, even motorcycles with wet clutches.
I'm the OP so it seems no problem with T6 Rotella in 5W30 and I'm going with it. I know it's great at 15W40 so I'll expect the same. You have to love these modern synthetics.
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #8
I run T6 5w40 in EVERYTHING with the only exception being the wifes newer jeep compass that calls out 0w20.
So I use t6 5w40 in
Kubota MX5100
Bobcat 334 excavator
Ram/cummins truck
my saturn beater with 230k miles
Wifes beater nissan sentra with 240k
Scag/kohler 25hp
KAwasaki sxs
Logsplitter with 16hp briggs
Thanks, LD1
   / Any problem using T6 5W40 syn in my Grasshopper w/25HP Kubota? #10
So I use t6 5w40 in
Kubota MX5100
Ram/cummins truck
Scag/kohler 25hp
KAwasaki sxs
My sister has a Jeep Wrangler Islander with the little V six that specifies 0w-20 or 5w -20 oil At under 35000 miles started eating that thin oil, never any blue smoke but was down to around 500 miles a quart.
Everyone in our family group likes the 5w-40 T6 so we switched that Jeep over about 5 years ago. The oil use dropped Dramatically. Runs as well or better than with the thin stuff.
No Plans to ever put the oil printed on the filler cap back in.
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
1982 MACK RD685S HOTOILER (A50854)
1982 MACK RD685S...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
1982 S&S FLATBED (A50854)
1982 S&S FLATBED...
