Any point in loading tires?
/ Any point in loading tires? #1
rtvman
Michigan, Grand Rapids
97' L35, 04' RTV900
Do you guys think there is any benefit in loading the tires? My tractor tires are loaded and I see a lot of benefit to that. I'm just wondering if the benefits would be the same with our RTV's.
/ Any point in loading tires? #2
Hey Kevin
The only thing I'd load them up with is Slime.
As for your question, I'd say no. Loading tractor tires is to lower the center of gravity and to act as a counterweight when using implements.
The RTV has an incredibly low center of gravity.
They haven't come out with a loader for it (yet...).
Brian
/ Any point in loading tires? #3
Seems like the ballast would centrifuge at high speeds and give an awful shake
/ Any point in loading tires? #4
</font><font color="blue" class="small">( Seems like the ballast would centrifuge at high speeds and give an awful shake )</font>
Steve.
I agree with you but would like to add, we're talking a RTV here. High speeds only occur on the RTV when they're on a flatbed. /forums/images/graemlins/grin.gif
/ Any point in loading tires? #5
So the top speed is about 25mph??, still seems fast enough.
What exactly is "slime" anyway? You have referred to this several times on various posts. Is this like a coating that can be applied to the inside of the tire to prevent air lost from punctures? I am curious to know what it is. Thanks.
/ Any point in loading tires? #7
Steve,
I was kidding. Just picking on how slow the RTV is.
Yes. I concur it may be an issue. I wonder what speed that would occur at? How much of a difference does tire size make?
Kevin,
Yes. Slime is a tire sealant. Check out info on it at www.slime.com It does a real good job. They're better stuff will instantly seal a hole up to 1/4".
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
PORTA POTTY (A68842)
