Any CUT's with full frames ?
/ Any CUT's with full frames ? #21
dfkrug said:
Well, my JD955s had a full frame. The 33hp engine was mounted on
four rubber mounts and the loader attached ONLY to the frame. In the
back, the axle/diff/PTO casting was bolted to this same box-section
frame. It made engine removal very easy....no splitting necessary.
I did not have the JD7 backhoe, which can be mounted with factory
brackets. My own hoe I mounted with a subframe attached to the MMM
ears on the frame and the axle casting at the rear.
The photo shows the tractor with engine removed.
The JD 55 series were built like riding lawnmowers and not like traditional tractors. The engine was not mounted directly to the transmission.
/ Any CUT's with full frames ? #22
Robert_in_NY said:
So if someone needs an industrial tractor loader then buy one but they shouldn't expect the OEM's to change the design because of a freak accident.
I hope that makes sense
I agree... a tractor with a back or box blade and / or a loader does not equal a bulldozer.. or a payloader...
soundguy
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
6ft Bush Hog Rotary Cutter (A61166)
6ft Bush Hog...
Ratchet Straps (A61569)
Ratchet Straps...
February 26 2026 (A64047)
February 26 2026...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61568)
2017 Autocar...
2006 Dodge Ram 2500 4x4 Truck (Diesel), VIN # 3D7KS28C66G203434 (A61165)
2006 Dodge Ram...
