Any CUT's with full frames ?
   / Any CUT's with full frames ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
Once You add a FEL and a backhoe, you end up with a pieced together half ***** frame, and the backhoe install locks like a major after thought.
So do any CUT's come from the factory (designed ground up) with a full frame ? ready for a FEL and backhoe that was designed for it ?
Thanks,
Slack
   / Any CUT's with full frames ? #2
From a previous thread on this issue the ones that will jump on you for asking that question are the same ones selling those tractors . They are biased to the max and will tell you a frame is not required .
   / Any CUT's with full frames ? #4
I guess the 8N was so successful by using smoke and mirrors. Look, no frame AND a loader.
and a 9N. No frame!
How did we ever survive? :confused:
Those Ford engineers. What idiots.
   / Any CUT's with full frames ? #5
They didn't have the internet back then Mike so the N series owners didn't know their machines were faulty.:D
   / Any CUT's with full frames ? #6
MessickFarmEqu said:
Kubota B26/L39/L48/M59....thats the only machines I'm aware of that ship from the factory with the mounts already part of the framework.
Does the John Deere 110 come this way also?
   / Any CUT's with full frames ? #7
Thanks,
Slack
There are quite a few TLBs out there made specifically for what you ask. The Kubota BXs with backhoes were designed to use backhoes. Lots of choices in different sizes, it seems. What size in particular are you looking for?
   / Any CUT's with full frames ? #8
Yes, the backhoe mount is built into the Kubota BX22, BX23, and BX24 frame, that is why some Kubota dealers won't warranty the non TLB BX series that has had aftermarket backhoes mounted. I'm sure those weren't the tractors the OP was thinking about though. :)
   / Any CUT's with full frames ? #9
Must be why most (many) of them are still working today!! 60 years later...
Andy
The picture with the "red" loader has frame wrapping all around that tractor, but my concern was with the backhoe.
Just wondering with the "modern" CUTS, why did they not then just bolt the loader to the side of the motor, like they did in the good old days ? as I am hearing they did.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2016 KBAR 157595AL Pressure Washer Trailer (A51691)
2016 KBAR 157595AL...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2016 Genie GS-3369RT (A50123)
2016 Genie...
