Any computer (printer) experts here?
/ Any computer (printer) experts here? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We have a HP 3500N color laser. It's been fine for us for maybe 5-6 years. Last year, we got a message on it saying we needed a new fuser kit so we got one and replaced all the parts.
Fine & dandy.
Today, maybe 12 months later, we're getting the "need fuser kit" message again. Might be worth noting that the first several years created a LOT more prints than the last 12 months. I'm baffled on the (evidently) short life of this replacement fuser kit which I'll add, was obtained through HP as an original replacement. I don't do the cheaper knock offs on repairs/maintainence.
I've posted on HP's site to inquire why... with no responses yet. Thought I'd ask here just in case anyone might have an idea.
The printer is currently working 100% fine, it's just the message on the screen for the fuser kit.
/ Any computer (printer) experts here? #2
I'd say 5-6 years is a few years past the life span of just about any printer out there. Time to chuck it and buy new.
I know...not much help but I do design microprocessors for a living and we design for a life cycle of about that long.
/ Any computer (printer) experts here? #3
Hmmm?
What wears out in a microprocessor? Or is it a built-in calendar that says "times up" ??
As to HP messages, they've been caught handing out "low ink" warnings on their printer ink leading to early replacements when the ink wasn't gone. A big class action suit emerging for almost all HP printers, near as I can tell.
I'd suggest ignoring the fuser kit warning until it doesn't perform any more. Just what I plan to do with the "low ink" cartridge warnings. When the color goes bad, then replace it.
Also HP was caught saying cartridges were out of date, and suggesting their use would nulify mfg's warranty.
But, printers are cheap, just the ink is expensive. :)
/ Any computer (printer) experts here? #4
Fine & dandy.
Fuser kits "expire" based on page counts. I'm not at my office where I have a CLJ3700 (same basic printer) to confirm what I'm thinking but I believe one of the sample pages you can do will show the page count where the fuser was installed. When you replace the fuse in this printer, you should have gotten a message asking if you replaced it, saying yes resets the count for the new fuser.
Assuming you really have not used the printer nearly as much as the previous years, I'll go on the thought that the page count didn't properly get reset. Should not happen when using HP supplies at the correct interval but anything is possible.
You can manually reset the count if you do the following I copied from the HP service manual.
To reset the fuser count
1. Press MENU to enter the MENUS.
2. Press (down arrow) to highlight Configure Device.
3. Press (check mark button) to select Configure Device.
4. Press (down arrow)to highlight RESETS.
5. Press (check mark button)to select RESETS.
6. Press (down arrow)to highlight RESET SUPPLIES.
7. Press (check mark button)to select RESET SUPPLIES.
8. Press (down arrow)to highlight NEW FUSER KIT.
9. Press (check mark button)to select NEW FUSER KIT.
10. Press (down arrow)to highlight YES.
11. Press (check mark button)to select YES.
The fuser count is reset and the printer is ready to use.
To be honest, I really am not impressed with many of the current market printers. I've considered consolidating my printers into one device (rather than MFP, color laser, standalone BW laser) and just have not liked the hardware available that isn't way beyond $1000.
/ Any computer (printer) experts here? #5
Hmmm?
I agree with Beenthere. Run it until it won't print. Only that printer isnt cheap. Those color laser were made to last. One thing we found was the problems with some of the older model lasers became more prononced when the printer was used very little, if it not being used much print some pages. Keep it powered on all the time is also a good thing.
/ Any computer (printer) experts here? #6
I tend to agree with you that the page count should have been reset when the fuser was replaced. If it were me, I'd try to reset it. If not, then just run it anyway until the quality of the output suffers. Then worry about it.
/ Any computer (printer) experts here? #7
When my printer tells me it's out of ink I take the cartridge out and put a piece of tape on it and reinsert it while lying to the printer and telling it Yes I Put IN A new Black, Yellow or whatever. It lasts weeks if not months and it's used daily for three kids homework. This works especially good for color since I seldom need something in color anyway.
I like to use all of anything I buy. Like that last 1/8 inch on the brakes. The last mile on the oil change service minder. Flashlight batteries. A battery too weak to us in a flashlight seems to last months in children s toys. Not electronics but the singing dog etc. The heat from the oven if it don't smell and if the humidity is needed. Same thing for the dryer heat. I have an exhaust fan in the laundry room I turn on to pull the moist heat out. I haven't figured out what to do with a broken socket or even a car or truck I don't need and isn't worth giving away.
/ Any computer (printer) experts here? #8
I've been known to reset pages counts when I don't feel like buying the "kit" required. Fuser for this printer isn't expensive even for an HP OEM part. Try buying an OEM fuser for a Lexmark T634... ouch.
I have had aftermarket fusers and other consumables not reset the counts in the past but usually it's because of a fuse that is designed to blow upon in stall which is what resets the count. Not all rebuilders of such products replace the fuse. Other's just wipe the used toner off a part and sell it as "refurbished". That's ok for somethings, but for consumables it's not.
/ Any computer (printer) experts here? #9
Hmmm?
Temperature cycling kills it. When you bend a metal bar with your hands back and forth to break it in half, the metal fatigues as it heats up and cools down in the bending area and that's what finally breaks the piece of metal. Same thing in electronics.
/ Any computer (printer) experts here? #10
Yeah, I got an e-mail last week about a proposed settlement in which you can get a $5 discount when you order new cartridges directly from HP.:rolleyes: Sounds like a great deal, right?:laughing: I just deleted the e-mail.
My HP printer will be 3 years old in just over a month. I replaced the cartridge when the "low ink" warning came on the first time, but never since then. I learned pretty quickly that I can still do lots of printing before actually running out of ink, so I do just as you said; wait until it doesn't print right to replace a cartridge.
/ Any computer (printer) experts here? #11
Yes you can try to reset the page count, that might work. Fusers also work by temperature. The fuser is what burns that black metallic carbon on the paper. Sometimes the fuser doesn't get hot enough so you get replace the fuser warning. Some printers you can cheat and set the temperature lower and the warning will not go off for a long time but you can get some black dusty sheets. When you handle the fuser bulb, make sure you don't touch it with bare hands just like a auto head light it will shorten the life of it. The same with the cartridge, don't touch the 'ink' area. It is a biodegradable organic material and will break down with time and light as well.
/ Any computer (printer) experts here? #12
Never used a Color Laser printer, (I rarely print anything.) My woman has HP all in one that we refill many many times both color and Black. I used my printer once 3 (almost 4 years) after buying Her computer (HP) came with it. last week after 8 or 10 months I tried to use it 2nd time and it would not work. :( her Multi function printer is close to 10 years old and works fine... the NEW HP stuff seems pretty crappy compared to what it was 10 years back.
Her HP pc has been a problem since day one. same with the HP camera we bought a few weeks after the PC it lasted 6 months and was messing up, HP kept telling us to try different things until the warranty was up and they offered us 25 bucks of a NEW HP camera ! lol. I will probably never buy anther HP device...
Mark
/ Any computer (printer) experts here? #13
SPIKER;2164894 last week after 8 or 10 months I tried to use it 2nd time and it would not work. :( [/quote said:
Mark, the print nozzles will gum up with dried ink if not used in a long time.
/ Any computer (printer) experts here? #15
it is/was not the print head gummed up it is the printer communication it wont even try to print it goes into a comm fault and wont even try to boot just blinks and grinds then flashes & goes dead...
When I raise the cover to pull the print heads the drive mech wont even move the heads to the removal pos.
I cleaned & re-filled the black cart and it still has same issue.
Mark
I think you hit the nail on the head!!
It stopped on a print yesterday. I took the fuser out....looked at it....shook it...(don't know why I shook it :laughing:) and put it back. I then noticed on the screen, it had some question/answer.... and scroll down... then it had a reset counter choice.
Realizing this worked on page counts, I hit reset.
Working 100% fine now!
:thumbsup:
/ Any computer (printer) experts here? #17
I... I took the fuser out....looked at it....shook it...(don't know why I shook it :laughing:) ....
Anything made by HP deserves a good shake now and then... just to teach it a lesson! :laughing:
/ Any computer (printer) experts here? #18
Use it 'til it dies, pitch it, and go buy a brother 7840W (or equivalent at the time), and be done with it. Get a 9840W if you need color.
I have 4 of them, good quality, good price, easy networking, etc. Great printer, great fax, good scanner, great copier with doc feeder. 299cdn, likely cheaper south of the 49th....
-Jer.
/ Any computer (printer) experts here? #19
-Jer.
Yup :thumbsup: Brother my 2nd printer 11 years ago but was took out by lightning 2 years later, 3rd one was to replace the first one and it last me 5 years and got taken out by lightning again, now I have the 4th (all-in-one 5460 ) 4 years now, I have learned to unplug all my components when a thunderstorm comes up;)
so really I cannot tell for how long a brother will last but do know they are user friendly, Now as for my first printer being and HP had prier to all of the others last about 2 years and I never could figure out how to use it correctly having to press 1 button to press another button to press another button just nutted it up and fried it was certainly not the average Joe user friendly printer,
I think this person knows how to put a fix to the HP printers:D
YouTube - Printer Dissatisfaction Has Been Resolved See Description
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
UNVERFERTH 14' FIELD CULTIVATOR (A63291)
UNVERFERTH 14'...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
