Any advice for drilling ?
/ Any advice for drilling ? #21
A quick way to determine, to some extent, what you are up against when drilling unknown metal etc. is to do a center punch test with a quality punch. If the punch curls back leaving no indentation in the material a HSS bit may have a problem. If a slight dent is made, HSS with slow speed, cutting oil and plenty of time may get results. It's a judgment call at punch time. I didn't say LUNCH time although you may need to take a lunch.:laughing:
Lots of good ideas & advice - thanks, guys. I'll start of with Sandbur's punch test and if it just bounces, I'll try heating with the oxy torch and try the punch test again. If I get the same result ... then I'll worry about lunch.
:thumbsup: - I use the point on a pair of scissors. ... If they scratch the metal well, then OK for HSS. If they require a lot of pressure to get a scratch, maybe still OK for HSS. If they just skid on the surface its Carbide time. ... I dont like to keep sharpening my punches. :confused3:
larry
/ Any advice for drilling ? #22
Some strange ways to test hardness...:D
The accepted machine shop practice is to use a file. If a file cuts the metal, it's workable. If not, it's hardened and won't drill with high speed drills. Simple and effective.
Cobalt drills are nothing more than high speed steel with with cobalt added for toughness. I prefer M42 Cobalt, Titaninum Nitride coated for chip flow, however a 'Cobalt' drill isn't any harder than high speed, it's just more resistant to to edge breakdown (dulling), which, in my case is moot because I sharpen every drill I use everytime I use them.
If you want to drill hardened steels reliabily, the only accurate method is to use a 'High Rock' die reclaim drill. Hi-Rock's can drill glass, tool steel, hardened die plate or anything with a Rockwell above 58. 'Coolant' is water flooded at the point of cutting and they need to be run in a drill press. Hand drills wil break them as they won't tolerate off angle drilling or wobbling in the hole.
/ Any advice for drilling ? #23
Dont like to dull my files either.:D I assume the Hi Rock die drill is Carbide? ... probably straight flute.
larry
/ Any advice for drilling ? #25
Most cutting edges arent heat treated: they are just hard as is. Tempering doesnt help.
You can drill Hardox 400 with high quality drills and lots of pressure on the drill, but torching is easier.
/ Any advice for drilling ? #26
Would appreciate any advice for drilling snow plow cutting edge. The Plant Manager (bless her warm heart) brought a 7' piece back from the dump for me. I don't know what kind of steel it is or if HSS drills are good enough. Been procrastinating getting Cobalt, but is this stuff going to be real tough? Thanks in advance,
Jim
A woman that brings good stuff back from the dump - there's hope for this world yet !!!!! :D MikeD74T
That's what I was afraid of - so I have to keep making chips at a good rate so I don't overheat the bit. And use lots of coolant.
Yes - I got very lucky finding her!
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
2010 Deere 318D (A60462)
2010 Deere 318D...
Sdlanch SDLGC80 (A60462)
Sdlanch SDLGC80...
2016 Terex RL4 S/A Towable Light Tower (A60352)
2016 Terex RL4 S/A...
2022 Ram 2500 (A55973)
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
