Antique tool experts?
/ Antique tool experts? #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
I have lots of Grandads tools, some I'm not sure what they are and how used. Several torches, did they use kerosene? I have lots more...these are a few. I know the open end wrenches but why the large one with small slots? We used it to bend metal. One threaded, grease fitting one end? Punches different symbols, one a ********. Brass stencils lock together.
He started working as a machinist 100 years ago, then mechanical engineer, physician, osteopath.
/ Antique tool experts? #2
Stencils slide together to form a word template to trace or paint. Second last one is to pull cable or wire (we used one to stretch fence). I would image the punches are for proof marks. The combination squares are common and still made today.
Thanks so much. My ignorance but what are proof marks?
/ Antique tool experts? #4
I have most of the same tools except pics 3 & 5.
1 not sure what a fixed wrench with that size opening would be used for. Probably specific for working on some machine.
I have 2 of the adjustable flat wrenches with the wood handle. Mine were made by Coes Wrench Co. in Worcester, Mass.
2 looks like tips for a grease gun.
4 are squares, one has adjustable angle.
6 is an older version of today's vise grip pliers.
7 is a spring loaded adjustable wrench.
8 is what was used as a torch.
9 is a cable or wire puller.
10 is the flip side of 7.
I'd agree about the stencils and punches are for proof marks.
As a machinist he probably made some of his own tools as my father did. He probably made the proof mark punches as his identifying mark to stamp his tools.
Thanks. What was used in torch, fuel oil or kerosene. I think only Moe Howard used gasoline.
/ Antique tool experts? #8
#7 and #10 are "Adjustamatic Ratchet Wrenches". Lots of torque with the ratcheting action for faster tightening/loosening.
/ Antique tool experts? #10
I have some of those, also.
The "blow torch" which when I bought it at a garage sale had a non working pump but the accelerator pump from a Rochestor two barrel carb provided the seal...just had to do a little machining to make it fit. Huge amount of cheap heat from one of those but they need a bit of warm up time first.
I have a small wire grip somewhere that's the same in operation but different shaped. Mine has long smooth flat jaws that don't damage the wire any.
I've a couple of the spring loaded jaw speed wrenches. I bought the first one new back in the 70's, a 10" one, and used it at work on a power line crew, very handy!
The square on the left is a machinists square with a center finder so you can mark the center of a shaft. Looks like yours is missing a locking bolt on the protractor part.You can rotate it to have the ruler at an angle through the base. Mine is a Starrett brand and the price of it new would shock you. The one on the right is a fixed 90[sup]o[/sup] angle but adjustable leg so handy also. You can still get both new and much cheaper than the Starrett one.
/ Antique tool experts? #12
7 and 10 also get used to remove the copper caps from resistance spot welder electrodes
/ Antique tool experts? #13
Yes, some of them may be slightly discouraged)
/ Antique tool experts? #14
9 looks like a clamp for lifting sheet metal you hooked the eye on to crane and placed the V opening over edge pf plate and then as you lift the cam tightens on plate never trust them! Especially old one's!
He has a carbon arc welder there. Strange looking thing, like a reflective parabolic heater with wire coil in back. Runs on 110v, has two carbon rod holders either side. He showed me years ago how to use it bringing carbon rods together, then slowly apart you get an arc at gap where you can weld.
/ Antique tool experts? #16
9 is a cable, or wire puller.
/ Antique tool experts? #17
I'd suspect #1 is a tool to bend or adjust flanged material such as the lid or lip of a metal box, again perhaps the flanges of vehicle fenders.
Thanks so much again. Other odd ones I'll post when I can. I just remembered a trunk full of stuff he had when he was in WWI. I'm 65...but way before my time.
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2009 STRICK 53X102...
