Antifreeze suggestions
/ Antifreeze suggestions #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Hope this is the right palce to ask about antifreeze.
Here are some questions
1) What brand other thean OEM of antifreeze do folks use? The premixed 50/50 by Prestone looks good. What do you all think?
2) How often do you change antifreeze? Hours of use? Years? Color?
Bob
Bob
/ Antifreeze suggestions #3
NAPA on sale.
I drain, flush and re-fill (with new) in all my tractors each fall.
Trucks and cars as needed. (test current anti-freeze)
Diesels, ESPECIALLY wet sleeve diesels have a tendency to cavitate (in cooling system) In those wet-sleeve motors, that leads to holes in the cylinder sleeves. Anti-freeze becoming acidic is also a major factor in this malady. Fresh (clean) coolant and a good anti-cavitation additive helps prevent expensive problems. (I use an additive from Fram in my diesels)
Old anti-freeze goes to my neighbor who puts it in tractor tires. (I still use Calc/Chlor or windshield washer solution myself)
/ Antifreeze suggestions #4
NAPA on sale.
How do you test your antifreeze?
What additive from Fram do you use?
Why each Fall in your tractors and only as needed in your road vehicles?
Bob
Bob
/ Antifreeze suggestions #7
Many oem dealers sell the anti cavitation electrolysis addative.. for NH it is FW-15 and about 5$ to treat a couple gallons.
Soundguy
/ Antifreeze suggestions #8
Soundguy
Thanks, good to have a name and cost.
Bob
PS What do you use?
Bob
PS What do you use?
/ Antifreeze suggestions #11
Since 80% of my tractors are fords/ NH units.. I use the CNH product.. My 5000 and 7610s each take an entire bottle for themselves.
If you look around, some diesel antifreezes are 'precharged' with cavitation addatives.. though.. I have not tried them, and instead have followed my dealers and manual's recomendation of 1 bottle addative per collant change.. etc.
If your unit uses a coolant filter.. some of those can be bough pre-charged too..
Soundguy
/ Antifreeze suggestions #12
Soundguy
/ Antifreeze suggestions #13
</font><font color="blue" class="small">( How do you test your antifreeze?
Litmus test. (acid/alkainity) One of those cheap testers with the floating balls. Can't recall their name.
I don't have the part# with me. It's available at any good truck parts store. I've also used John Deere additive. My Deere has a coolant filter. Like SoundGuy said, some of those filters come pre-charged. I get mine WITHOUT a pre-charge and add my own. (Filters are common to most Deeres with coolant filter. System volume varies considerabley. Additive used is based on coolant system capacity)
Car and truck use "lifetime" coolant. If and when it NEEDS changing, I'll do that. Diesels that log a lot of hours need fresh coolant to lower the chances of the electraulysis (sp?) (wet-sleeve pitting) All three tractors combined require a total of 6 gallons of coolant. Seems like a low buck compared to new cylinder sleeves.
Bob )</font>
/ Antifreeze suggestions #14
Bob )</font>
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
