Antifreeze Leak
   / Antifreeze Leak #1
Eastbx
new holland tc40a
Gentlemen,
I've been noticing a small leak of antifreeze coming from a valve on the right side of my 2004 TC40A. I don't know what this valve does, what's it called or if this is normal...? I'll attach a couple of pictures for more details. Maybe someone can give me some advise or direction on how to fix this relatively small problem? It would be greatly appreciated.
   / Antifreeze Leak #2
I'm not familiar with this tractor but by picture looks like it maybe the engine block coolant drain valve.
   / Antifreeze Leak #3
According to the NH parts diagram it look to be a "DRAINCOCK/TAP SUPPLY Fitting"...
Hard to see, but it doesn't look like the tap is leaking from the drain, it looks more like it's leaking around the threads between it and the block. Drain the coolant, unscrew the tap, clean up the threads. If it looks ok, re-install with some thread tape or pipe joint compound. If it's too knarly looking, replace it.
   / Antifreeze Leak #4
Eastbx,
Did you end up fixing the leak? What did you end up doing? How well is it working now?
BarnieTrk :confused3:
3500# TANDEM BRAKE AXLES (A51248)
3500# TANDEM BRAKE...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A51248)
UNUSED FUTURE...
