Antifreeze degradation
/ Antifreeze degradation #21
What is everyones thoughts on flushing?
Use a flush additive or just flush with distilled water?
Just like antifreeze, the type of flush is going to depend on the metals in your engine. Engines that are built still using metallurgy from a few decades ago don't contain many/any light metal components like aluminum or alum. alloys. Radiators were copper, then bronze, then later aluminum and finally plastic in the flow path. So different engines take a differnt kind of flushing chemical. If in doubt, use water.
rScotty
/ Antifreeze degradation #22
Flushing - - I don't fight it. Fill with good old farm spring water - run for 10 to 15 minuets - drain.
/ Antifreeze degradation #23
^^^^^^ me too!!
/ Antifreeze degradation #24
Since we are talking about antifreeze and many of have dogs, do not forget that ethylene glycol is toxic to dogs and dogs are attracted to its sweet taste. Keep it stored out of the way and do not let your drain pan sit uncovered. :tombstone::x::tombstone::x:
/ Antifreeze degradation #25
Back 60 years ago, when I was just getting into vehicles and maintenance,there was a 2 part flush that came in a tall cardboard container as I remember and I think it was a Dupont product. You would dump the cleaner part into a warm engine and run it for quite a while, then drain it and flush with fresh water and drain again and then fill with the neutralizer portion of the product in it and run it for quite awhile again before draining and flushing again. If my feeble memory serves me right I believe that at some point the thermostat had to be removed and the heater had to be run on high while all this was going on. Then, after flushing well again, you drained it and re installed the thermostat and filled the system with a 50/50 mix of water and antifreeze.You had to run it enough to warm it up well and make sure all the air was bled out and top it off again, a real pita.I do remember that some of those old cars had really filthy cooling systems and as often as not you would end up taking the radiator off and having it rodded out.
The most recent experience I had with cooling system problems was with a boat I had that had twin 3208 Cat engines that were fresh water cooled with a raw water heat exchanger.I did some pretty extensive work on the boat including the cooling systems and at that time Cat recommended using de ionized water with the anti freeze mix.
There are a lot of different thoughts on this subject, especially with the newer stuff with so many different alloys.
2003 Proclaim T/A Vacuum Tank Trailer (A64194)
2003 Proclaim T/A...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
CAT HM415C Mulching Head (A65579)
CAT HM415C...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
2015 Ford Transit Connect Van, VIN # NM0LS7E74F1193985 (A65563)
2015 Ford Transit...
Vandale Feed Wagon (A65640)
Vandale Feed Wagon...
