Antifreeze/Coolant
/ Antifreeze/Coolant #1
margaritaman
Texas
L3400HST
Can I use the same coolant in my L3400 that I use in the cars or does the diesel engine require a special mix? If so is it available widely or only through the tractor dealers? Thanks
/ Antifreeze/Coolant #2
Normally ethyline glycol (the green stuff) is used in both applications. Recently, a different type (orange stuff) is used in GM and Ford vehicles. It's not the same stuff; the two types cannot be combined; the orange stuff will oxidize easily (and turns into goo) if the radiator cap leaks air into the system upon cooling.
Your manual most likely says to use the green stuff (ethyline glycol). My B2400 manual states that; that's what I use; mixed per the manual in a half-n-half mixture with distilled water (or filtered well water).
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
Spirit Bike (A64557)
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
