Antifreeze change on my GC
   / Antifreeze change on my GC #31
For those who missed it, I am re-posting a paragraph from a thread about antifreeze. Here a member is talking about additional benefits gained from using SCA Diesel antifreeze in an engine where the manual does not specify, or require it.
His perspective bolsters the argument that there is definitely a benefit from doing so.
MF being concerned about internal corrosion, now seems to be the logical reason for their suggesting annual coolant replacement.
To me, annual replacement still seems to be excessive, regardless of which type of coolant you use.
fieldserviceengineer, Re: Antifreee question?
Even if an engine does not require supplemental coolant additives for cylinder wall cavitation pitting protection, the common supplemental coolant additives available will improve general metals corrosion protection. Nitrite as found in the old Nalcool product, Pencool additives, Fleetguard DCA2, Caterpillar coolant additive, Baldwin BTE, as well as Wix and Napa products....will improve the ferrous metals corrosion resistance even if the engine does not need that additive for pitting protection. The other supplemental coolant additive is sodium molybdate. It is a potent aluminum corrosion protection agent as well as being part of the most robust pitting protection available. More engines are being built with increasing amounts of aluminum content such as cylinder heads, water pumps, as well as thermostat housings and now radiators. Coolant additives composed of nitrite and molybdate are sold by Baldwin as BTA, Fleetguard as DCA4 as well as there are several coolants that use the combination of nitrite and molybdate as all or part of the ptting protdection and general metals protection. The most common (but not the only) are Fleetguard ES Compleat, Fleetguard Fleetcool EX, Caterpillar ELC OAT with nitrite and molybdate, Caterpillar Diesel Engine Antifreeze Coolant, Shell Fully Formulated Phosphate-Free, plus a few others whose names escape me at the moment.
Entire thread: http://www.tractorbynet.com/forums/oil-fuel-lubricants/228436-antifreee-question.html
   / Antifreeze change on my GC #32
I've changed the anti freeze in mine twice now and the last time I just flushed it with water as well.There was no corosion or scale build up anywhere that I could see.I have a permanent mounted heater behind the seat for winter use.[ I just made it permanent this fall] it was getting to be a pain to drain and fill the system every spring and fall. .I do use the Diesel type long life Anti freeze as well. The tractor only has 1745 hrs and slowly climbing :laughing: Larry
I'm juts curious, Will having the increased forward and return hose affect engine cooling? Would it slow down the flow?
   / Antifreeze change on my GC #33
Thanks for reposting tht Ray.
Is he saying running Cat ELC for example, will not harm our tractors?
   / Antifreeze change on my GC #34
I can't answer that, you could ask him directly.
I can't see any "harm" using any current type of coolant, If the label does not warn against it.
   / Antifreeze change on my GC #35
Changed my 2006 gc2310 and used Shell Rotella ELC. I presume it is safe to use ??? It says no other additives needed.... Just want to be sure.
   / Antifreeze change on my GC #36
I think (according to manual) as long as it is ethylene glycol based, you should be fine!!
KARCHER PRESSURE WASHER (A51244)
KARCHER PRESSURE...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
