Anti scalp roller placement
/ Anti scalp roller placement #1
wanasrx
NY
Kioti 3054
I just purchased a anti scalp roller for my 6' rfm. Is there a rule of thumb as to what height that I place it at. It's going on the front middle section.
Thank You
Anyone? or maybe someone can measure their exiting one. I'm looking for a distance from the bottom lip of the frame/shroud to the bottom of the roller.
thank you
Rich
/ Anti scalp roller placement #3
The ones I've owned/seen (I no longer have one to measure for you) were set so that roughly half to three quarters inch (no more than 1") of the roller extended below the front center deck housing. It's really only there to prevent damage from accidental high-centering. Usually the tractor operator knows where the humps are, and steers so that one set of side wheels or the other "rides the hump". Of course, I'm sure there will exceptions for those that set the mowers to leave a very short cut.
//greg//
/ Anti scalp roller placement #4
I have found that on my lawn, those are a waste of money. I mow at about 4" and my terrain is not competely smooth. I would recommend trying it without the roller first. Maybe you could get your money back.
/ Anti scalp roller placement #5
I added the floating attachments to my rfm, which were not on it when purchaced. When I did, I started getting scalping (i.e. just nose digging from the front center). Ordered and installed the roller. I mow fairly high but have a lot of uneven areas. I'm at work but, if helpful, I'll take a pic when I get home and post it.
Haven't had any scalping since installing the roller.
Tom
Thanks for all the replies. I am getting scalping and the middle of front deck digging in right now. A pic would be great, if it's not to much trouble, could you through a ruler or tape measure in there?
Thank you very much for the help
/ Anti scalp roller placement #7
Sorry the lighting and angle are not great. RFM is up on blocks with sun from the back. If you can't make it out, the front/bottom lip of the deck is about a 1/16" to maybe an 1/8" in off the block. the bottom of the roller measures about 3/4" below that (think you've already got that advise, this only confirms with pic). As I said, since putting on the roller, I've had no scalping problems.
Tom
/ Anti scalp roller placement #8
From a little further back, for perspective. Again, sorry for the sun and angle.
Tom
Tom,
That's great. Thank you.
Rich
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
208735 (A60430)
208735 (A60430)
(3) MILITARY CARGO BOXES (A64281)
(3) MILITARY CARGO...
2001 Ford F-450 Super Duty Flatbed  7.3L Power Stroke Diesel (A63688)
2001 Ford F-450...
