Oil & Fuel Anti-freeze for a D2050
   / Anti-freeze for a D2050 #1
Roy_in_NC
I own a Mitsubishi D2050 (figuring it was manufactured in 80's) and I can't find what type of anti-freeze I'm suppose to use in it. I have pink Chevron Delo Extended Life Prediluted 50/50 Coolant/Antifreeze here, will it work safely? It states that its:
1. Compatible with conventional antifreeze. (I assume conventional anti-freeze is the green stuff).
2. ...recommended for all heavy duty engines using all fuel types including Caterpillar, International, Cummins, Detroit Diesel, Mack, MTU, John Deere, JI Case, Ford, GM, Volvo, and other original equipment manufacturers (OEMs). Recommended for use in the cooling systems of all types of industrial internal combustion engines.
3. Chevron Delo Extended Life Coolant/Antifreeze PG provides maximum protection for all 6 basic cooling system metals found in most heat transfer systems.
4. This product is recommended for use in: All heavy diesel, gasoline and natural gas powered heavy duty engines.
Source: http://www.dooilco.com/pdf/Coolants/Delo.pdf
   / Anti-freeze for a D2050 #2
I don't think it matters what kind you use. When it was manufactured the choices were seasonal or permanent.
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
