Oil & Fuel Anti-freeze for a D2050
   / Anti-freeze for a D2050 #1
Roy_in_NC
I own a Mitsubishi D2050 (figuring it was manufactured in 80's) and I can't find what type of anti-freeze I'm suppose to use in it. I have pink Chevron Delo Extended Life Prediluted 50/50 Coolant/Antifreeze here, will it work safely? It states that its:
1. Compatible with conventional antifreeze. (I assume conventional anti-freeze is the green stuff).
2. ...recommended for all heavy duty engines using all fuel types including Caterpillar, International, Cummins, Detroit Diesel, Mack, MTU, John Deere, JI Case, Ford, GM, Volvo, and other original equipment manufacturers (OEMs). Recommended for use in the cooling systems of all types of industrial internal combustion engines.
3. Chevron Delo Extended Life Coolant/Antifreeze PG provides maximum protection for all 6 basic cooling system metals found in most heat transfer systems.
4. This product is recommended for use in: All heavy diesel, gasoline and natural gas powered heavy duty engines.
Source: http://www.dooilco.com/pdf/Coolants/Delo.pdf
   / Anti-freeze for a D2050 #2
I don't think it matters what kind you use. When it was manufactured the choices were seasonal or permanent.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
