Another use for Fluid Film
   / Another use for Fluid Film #1
ccsial
Veteran Member
NorthWest Illinois
(Kuboto L3400) (Ford 1900 4WD w/FEL) (Deere X748SE) All bought new
I went out to clear off 8 inches of wet heavy snow, The stuff that always plugs my blower. This time I had a thought and sprayed the chute and impeller down with fluid film. Two hours of blowing and no plugged chute, not even any sticking to it. It really worked.
   / Another use for Fluid Film #2
Nice. Maybe I'll try it on the underside of my mower decks next year. :) Just got my shipment last week. Sprayed it on the moving parts of my front blade. Nothing to report yet but everyone who uses it swears by it.
   / Another use for Fluid Film #3
Never heard of it! Use to use Garry's "It" silicone spray! Was suppose to coat my mower bottom and blower chute with this stuff:
EZ-Slide Alkyd Based Graphite Lubricating Paint
But of course never got around to it and now we're facing this winter blast!!! :( ~Scotty
   / Another use for Fluid Film #4
a year ago they sent me a free sample to try. i love the stuff. just ordered a couple more cans. its fantastic stuff. doesn't wear off easily. like wd40 but sticks like grease.
   / Another use for Fluid Film #5
Saw some of the posts here about Fluid Film and bought a spray can to try on my hydralic cylinders to reduce possible rust. I had been using WD 40. Based on the praise of the stuff here on TBN I thought I had better try it. I sprayed it on my backhoe cylinders since it is currently off the tractor and I want to reduce chance of rust. I went back to the backhoe after a couple of weeks and the cylinders were pretty covered with flying bugs, gnat like. They must have liked the stuff.
   / Another use for Fluid Film #6
ha!!! at first i hated the smell of it. its so funky, but now i really like it. smells kinda good. i did the same thing with my hoe. it has been on there for a few months now and there is a really nice coating still on it. it doesn't evaporate away. leaves a coating kinda like spray on lithium grease.
   / Another use for Fluid Film #7
Will this stuff harm the seals in the front of the cylinders?
   / Another use for Fluid Film #9
It does not contain solvents which is a good thing when it comes to seals. The solvents in allot of products can dry them out and actually cause damage.
Fluid Film contains no solvents. That statement alone means a number of things:
1) No evaporation. No evaporation means more useable product, which in turn means a much better value for your money. Most competitive products contain as much as 70% solvent, meaning most of what you spray evaporates and contaminates the atmosphere.
2) Non-tacky application. With solvent-based materials, the end product ends up being a gummy, sticky mess. Fluid Film will NEVER get tacky, retaining a super-slick consistency that provides excellent lubrication for moving parts on all metals.
3) Eco-Friendly. No solvents means no ozone depleting chemicals contaminating the atmosphere. It is classified as non-toxic and non-hazardous and is safe to be used inside the home, as well as out in the field.
Fluid Film is manufactured using an all-natural lanolin base. Lanolin is of animal origins, extracted from the wool of sheep, which use it as a waterproofing wax to aid in shedding water from their coats. It has been used for centuries for its medicinal and rust-preventive properties.
From one of our site sponsors Kellsport Prouducts proudly presents Eureka Fluid Film
   / Another use for Fluid Film #10
[Quote:]
Originally Posted by roadhawk
This was my first response too when I read it but laying in bed last night for some reason it popped back into my mind. Soooo...... how about it from the main man? Will it mess with the seals over time (so slick that they don't seal as well maybe?), and the bit that gets through the seals, will it mess with the hyd-oil?
I had to get a tech opinion on this. Here it is.
A) Will not effect the seals. Fluid Film itself is probably no slicker than the oil behind the seal. It's just not petroleum based. Fluid Film is not known to have any significant effect on rubber.
B) If some were to get beyond the seal, it would certainly be an insignificant amount. And even if a more substantial amount were to mix with the oil, there is no known negative issues.
__________________
Eureka Fluid Film Warehouse Distributor
I forgot to add bob's reply from the fluid film thread in the oils and lubes section. http://www.tractorbynet.com/forums/oil-fuel-lubricants/156161-eureka-fluid-film-7.html#post1803012
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
1992 MACK RD688S KILL TRUCK (INOPERABLE) (A53843)
1992 MACK RD688S...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
