Another stuck PHD auger- modification of the standard pipe wrench methodology
   / Another stuck PHD auger- modification of the standard pipe wrench methodology #31
Why not just use a manual transmission 3 or 4 speeds and reverse in the pto line????
Size. It would be so long that it would be about the same as a two-piece drive shaft. If that would work in your space, it would be much simpler.
I was thinking of a device not too much longer than a PTO extension, that could be slipped on the PTO shaft when needed.
Another idea is 2 spur gears in a case, with one input shaft and two output shafts. If stuck, simply move the PTO shaft from one output to the other.
Bruce
   / Another stuck PHD auger- modification of the standard pipe wrench methodology #32
I never liked steel T posts around a horse pasture. Too much like a spear if a rider falls on the fence.
Many years ago we had a horse slice it's neck on a T post. The Vet said a half inch deeper, it would have bled to death. :eek:
I put plastic caps on the T posts
   / Another stuck PHD auger- modification of the standard pipe wrench methodology #33
A hydraulic orbit motor would be compact and stay out of the way. Easily reverseable vs shifting. Torque limited by choosing the proper motor instead of replacing shear pins.
2020 DRAGON ESP...
2020 DRAGON ESP...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
1994 International 3800 Bus (A54814)
1994 International...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
