Another Squealing Thread
/ Another Squealing Thread #1
jk96
Elite Member
Missouri
Kubota L6060
Hi Everyone,
Here's another strange noise thread for you. I own a case DX33 - 84 hours. I recently started noticing a loud squeal when driving. Sounds almost like a squealing belt on a car, just not as loud or extreme. I've checked the hydrolic fluid, it showed just barely above the top line. The noise happens when its cold outside, the weather just recently warmed up and the noise stopped. The noise only happens when driving and quits if I let off of the pedal. It does not occur when operating the 3pt or FEL, only when driving and when cold outside. One other note, I also owned a dx24 before this tractor and noticed the same problem when cold outside. The dealer was unable to find any problems on the dx24. It also stopped when it warmed up. Anyone have any ideas as to the cause?
jk
/ Another Squealing Thread #2
I noticed maybe the same noise on my TC35 when out working on it when it was cold. I think it's the hydro pump. Can't be sure but the noise was coming from where the pump is on my tractor.
/ Another Squealing Thread #3
youve done your 50hr service right?
my TC33 (same tractor) whined big time due to the craptastic hydro fluid in it. The filter/fluid change has really quieted it down.
/ Another Squealing Thread #4
Probably a relief valve somewhere popping off due to the thicker cold fluid.
Ben
Yes,
I had my 50 hour service done at 58 hours on the machine. The noise is not a whine, but a loud screech or squeal.
JK
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2004 Chevy 2500 Pickup Truck (A66408)
2004 Chevy 2500...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
