Another RR track piece question
/ Another RR track piece question #1
BTackett
Knoxville, Tn
What are the pieces called that bolt the two pieces of track together? My neighbor found 4 of them on the side of the road and gave me two. They weight approx. 60lb each and have 6 large bolt holes in them. I need to know what is the best way to cut them each into 3 pieces to make front weights on my Mitsu. Chop saw? Cold cut saw?
thanks,
Bill
/ Another RR track piece question #3
I used my abrasive saw with no problems cutting some trac that I have on the ft. of my 372.
The trac is treated and may ruin a cold saw blade.
/ Another RR track piece question #4
Fish plates.If I were cutting them,I'd pop a cutting disk in my 7 inch angle grinder or use my torch.
Thanks for the input. Now I have to decide.
Bill
/ Another RR track piece question #7
Hi,
My torch cuts look like poo-poo on track so I used my cold cut saw to cut my self an anvil and it made a nice cut, but it took some teeth off the $100 blade in the process. TO be fair the blade was at the end of it's life anyways, which is why I tried it, but I think it might shorten the life of those blades a bit.
I would try the big grinder with cutoff wheel (might take a few) or an abrasive blade cutoff saw if you have one.
Wear a mask though with all the other safety doodads.
/ Another RR track piece question #8
They are called angle bars. Use a chop saw.
Mark
/ Another RR track piece question #9
My 2 cents-
Find a friend with a band saw (or buy one from HF for $160). Once you get it started, you can walk away. I have not found anything better for cutting thick stuff (and I have cut-off saws and a torch)
/ Another RR track piece question #10
bx24 is right about the band saw, but I don't have one handy.
Mark
Unused 2022 Miller Bobcat 260 Welder/Generator (A65579)
Unused 2022 Miller...
2022 EZ-GO ELITE...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
Superior Broom DT80J Street Sweeper (A65579)
Superior Broom...
