Another RR track piece question
/ Another RR track piece question #1
BTackett
Knoxville, Tn
What are the pieces called that bolt the two pieces of track together? My neighbor found 4 of them on the side of the road and gave me two. They weight approx. 60lb each and have 6 large bolt holes in them. I need to know what is the best way to cut them each into 3 pieces to make front weights on my Mitsu. Chop saw? Cold cut saw?
thanks,
Bill
/ Another RR track piece question #3
I used my abrasive saw with no problems cutting some trac that I have on the ft. of my 372.
The trac is treated and may ruin a cold saw blade.
/ Another RR track piece question #4
Fish plates.If I were cutting them,I'd pop a cutting disk in my 7 inch angle grinder or use my torch.
Thanks for the input. Now I have to decide.
Bill
/ Another RR track piece question #7
Hi,
My torch cuts look like poo-poo on track so I used my cold cut saw to cut my self an anvil and it made a nice cut, but it took some teeth off the $100 blade in the process. TO be fair the blade was at the end of it's life anyways, which is why I tried it, but I think it might shorten the life of those blades a bit.
I would try the big grinder with cutoff wheel (might take a few) or an abrasive blade cutoff saw if you have one.
Wear a mask though with all the other safety doodads.
/ Another RR track piece question #8
They are called angle bars. Use a chop saw.
Mark
/ Another RR track piece question #9
My 2 cents-
Find a friend with a band saw (or buy one from HF for $160). Once you get it started, you can walk away. I have not found anything better for cutting thick stuff (and I have cut-off saws and a torch)
/ Another RR track piece question #10
bx24 is right about the band saw, but I don't have one handy.
Mark
2022 EZ-GO ELITE...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
7002SFL (A61572)
7002SFL (A61572)
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
