Another RR track piece question
   / Another RR track piece question #1
BTackett
Knoxville, Tn
What are the pieces called that bolt the two pieces of track together? My neighbor found 4 of them on the side of the road and gave me two. They weight approx. 60lb each and have 6 large bolt holes in them. I need to know what is the best way to cut them each into 3 pieces to make front weights on my Mitsu. Chop saw? Cold cut saw?
thanks,
Bill
   / Another RR track piece question #3
I used my abrasive saw with no problems cutting some trac that I have on the ft. of my 372.
The trac is treated and may ruin a cold saw blade.
   / Another RR track piece question #4
Fish plates.If I were cutting them,I'd pop a cutting disk in my 7 inch angle grinder or use my torch.
   / Another RR track piece question #5
Torch, hands down.
David from jax
Thanks for the input. Now I have to decide.
Bill
   / Another RR track piece question #7
Hi,
My torch cuts look like poo-poo on track so I used my cold cut saw to cut my self an anvil and it made a nice cut, but it took some teeth off the $100 blade in the process. TO be fair the blade was at the end of it's life anyways, which is why I tried it, but I think it might shorten the life of those blades a bit.
I would try the big grinder with cutoff wheel (might take a few) or an abrasive blade cutoff saw if you have one.
Wear a mask though with all the other safety doodads.
   / Another RR track piece question #8
They are called angle bars. Use a chop saw.
Mark
   / Another RR track piece question #9
My 2 cents-
Find a friend with a band saw (or buy one from HF for $160). Once you get it started, you can walk away. I have not found anything better for cutting thick stuff (and I have cut-off saws and a torch)
   / Another RR track piece question #10
bx24 is right about the band saw, but I don't have one handy.
Mark
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
