Another Predator Engine Swap
/ Another Predator Engine Swap #31
It's not the shaft size on the engine. It's the adapter between the HF engine and the shredder I'm wondering about. If the new HF engines have a 1" shaft, I won't need any adapter.
How is it driven?
If the motor runs a pulley, just get another pulley of the correct size with a 3/4" bore.
If it goes through a connector such as a Lovejoy, you should be able to get the engine side with a 3/4” bore.
Aaron Z
Location Info Please
2005 LEEBOY 685B MOTORGRADER (A62129)
2005 LEEBOY 685B...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
Giyi-D39 QA Trencher (A60463)
Giyi-D39 QA...
