Another pin on to SSQA Conversion
   / Another pin on to SSQA Conversion
I forgot to post that I put about another 5 hours into this to this stage.
Pics:
In the following 2 pictures, you can see the angle iron I added to add strength to make up for the cut out of the 3x3. I drilled a hole to provide access to remove the bolt on the pin.
   / Another pin on to SSQA Conversion #52
I thinks you need to drink a couple pots of coffee and get your arse in gear :D
I degreased the orange ears, then sanded them to remove loose paint and rough up the orange paint.
   / Another pin on to SSQA Conversion #56
Looking pretty darn good so far! :thumbsup:
   / Another pin on to SSQA Conversion #57
Great Job..I considered a self build myself but ended up buying a direct fit. I also had to cut the ears off and weld my plate on but it all worked out well..
Its been 2 years now and Ive gotten used to the slightly less capacity of it.(due to extending the points out).But the multi uses have outweighed the loss of curl back etc..Your gonna love it.
   / Another pin on to SSQA Conversion #58
Oh one thing I added that was simple and SO useful was. on the cross bar, I welded a trailer ball on it. I cut the shaft off of the ball and then welded it onto it so it didnt interfere. Makes for moving the trailer simple
   / Another pin on to SSQA Conversion #59
Nice job ! :thumbsup:
Thanks for the comments guys. I will probably also put a receiver hitch or trailer ball on the cross arm. It is not a heavy cross member but for trailer moving it should be ok.
I have to admit, I was a little worried when I first started cutting the ears off -- a point of no return.
I sprayed some orange on it. I'm going to wait until the paint is hard on the QA before I fit up the plate on the bucket and weld it.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
2008 GMC C5 (A53422)
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
2025 Safety Basket Forklift Attachment (A55851)
2025 Safety Basket...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
