Another OUCH Log splitter
/ Another OUCH Log splitter #4
Clarence builds neat stuff. I remember last year he showed his trencher.
/ Another OUCH Log splitter #5
You can't see how much clearance there is between the ram and the blade so I question the wisdom of putting his hands there with the ram coming at the blade.
The other thing why don't he have the split wood feed off the end of the chute?
That is a neat idea.
Other than that I wounder how that would split a piece of oak or madron that has a lot of twist and a lot of knots in it.
/ Another OUCH Log splitter #6
What could possibly go wrong in that scenario...?
/ Another OUCH Log splitter #7
its scary to look at it !!
There is only half a handwith of clearance between the press head and the splitting blade... He has to be right on time to pull out his hands before getting them squeezed...
/ Another OUCH Log splitter #8
For his ingenuity I have to give it to him. Sticking your hands in that unit, no way in h*ll you'd see me doing it. If he cut out the bottom of the bale chute it would unload the wood automatically. Don't think it would take much more to automatically load a new block if he rigged something up on the side of the plunger.
I'm with charlie C, I'd like to see if that flywheel would handle a nice chunk of oak or apple before it came to belt screaching halt.
/ Another OUCH Log splitter #10
That splitter would have to be in my worthless category. What is he doing? Making toothpicks? I could split that type wood twice as fast by hand. Plus any horizontal splitter is a back breaker. It is a nice blivet.
/ Another OUCH Log splitter #11
All six of the splitters I've built have been horizontal. Vertical would have been the back breakers in my case. Of course, mine have all had conveyors across from the operator to take away the split wood.
/ Another OUCH Log splitter #12
Defective what kind of conveyor do you have? I believe that an old haybale conveyor would probably work.
/ Another OUCH Log splitter #13
Exactly!
Bale conveyors with a little structural improvement & angle at appropriate spacing across the chains. With a hydraulic motor pulling the chains, it'll run all day (or, at least until the trucks are all full...)
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
CAT 740 Engine (A68134)
CAT 740 Engine...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
213098 (A64276)
213098 (A64276)
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
