Charlton John
Hi, Another newbie question here for you guys. on my B2620 I have a clutch. The dealer (salesperson) advised no need to disengage the clutch when changing from Hi, Low Med. The manual says I should. Any comments.
These HST machines?
If so clutch isnt going to do anything for gear range changes.
The clutch is a PTO clutch. It's to be used when engaging or disengaging the PTO. Since I've always been stopped whenever I change ranges, I don't notice any difference between using the clutch or not, so I would tend to believe that it's not necessary for shifting between ranges. If this were a gear transmission, then that would be another story. Then, obviously, it would be required.
I know what you mean about confusing instructions in the manual. There are a number of lines throughout the manual that seem to contradict themselves. I think there's portions that are simply "cut and pasted" from one model's manual to another.
So, why does the use of the clutch seem to make it easier to engage/disengage 4WD and change ranges? I don't think this is my imagination.
Depends which tractor and powertrain you have. Gear drive with live PTOs should be clutched all the time. With the mechancial shuttle, you can but most do not.
If you have a hydro transmission, the clutch can take the driveline windup out but it also is useful in cold starts when the hydro may not want to spin readily or your battery is discharged.
Again on hydros /GSTs with master clutches, some guys use them for hooking up implements or inching towards a truck when doing loader work.
Also in a panic stop, you left leg wants to hit the clutch.
It really does not hurt a thing to use a clutch on a hydro / GST tractor unless you slip it continually.
