Another MX5200 Runaway Diesel
   / Another MX5200 Runaway Diesel #31
Yeah, something that big, you are definitely right. I think the rag trick only works up to a certain size. When the intake is big enough to suck in a small child, then you got to explore other options.
Stuff your head in.
   / Another MX5200 Runaway Diesel #32
So, you would approach the size of the engine, pull pin on grille guard, pull grille guard forward, put face near hood, pull hood release, open hood, lift hood, open air intake, stuff rags in.... All while a tractor designed for 3000 rpm max is racing at over 4000 rpm. You are braver than I my friend. A thrown rod or fragging turbo will kill you. Brave is occasionally the camouflage of DUMB. The design of the Kubota does not allow a safe way to kill a runaway. If there is a large CO2 canister handy then that is the best method. Unfortunately I left mine I the runway of the airport. Probably need to tow it at all times. Kubota has had the tractor one month. No concession or upgrade, despite numerous 5200's doing this. I MAY pay the difference and get the 5800. But their only offer has been a replacement of tractor only. Loader and valves get moved.
Wait a min... They are offering new tractor and you are unhappy?! Maybe you should buy a Deere! Lol
   / Another MX5200 Runaway Diesel #33
Usual cause of diesel engine runaway is overfilling the crankcase with engine oil. ...on a hot day The engine oil is forced into the cylinders through the exhaust sytem..and away she goes. To stop a diesel runaway, you must cut off ALL the air supply to the combustion chamber.
JIX
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
5' ROTARY MOWER (A52708)
5' ROTARY MOWER...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
