another MT180D question
/ another MT180D question #1
tnjind
Indiana
The tractor is leaking hydraulic oil from the "lowering speed" control knob under the front of the seat.
Is it a simple o-ring?
Can I replace it by removing knob? Does the knob "sit" on a taper, I can not pry it off with nut removed, but did try much force at all as I don't want to damage it.
I have looked at the down loaded service manual provided by a member here (thank you). but it stops at the end of chapter 5 and hydraulics are chapter seven.
The transmission diagram shows it being a simple cap held on with the four bolts, should I remove it to gain access to the seal?
/ another MT180D question #3
I have factory parts and repair manuals.
The o-ring shown as Part #16: 0830 1100 100 looks to be largish like perhaps 1.5"
Below the knob is a plug #13 that appears to also have a small o-ring PN #15
To get access at either o-ring the cap behind the knob would need removing and looking at the diagram caution as some parts could fly. *
4 machine screws , each corner to remove that cap. (knob is in center of said plate)
*blow up of cap and associated parts =22 items, many are small.
If the leak is not serious I would be tempted to live with it INHO.
Thank you for the reply, the leak is from the shaft itself. The leak is pretty good.
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
110 GALLON L SHAPE FUEL TANK (A64281)
110 GALLON L SHAPE...
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
