The tractor is leaking hydraulic oil from the "lowering speed" control knob under the front of the seat.
Is it a simple o-ring?
Can I replace it by removing knob? Does the knob "sit" on a taper, I can not pry it off with nut removed, but did try much force at all as I don't want to damage it.
I have looked at the down loaded service manual provided by a member here (thank you). but it stops at the end of chapter 5 and hydraulics are chapter seven.
The transmission diagram shows it being a simple cap held on with the four bolts, should I remove it to gain access to the seal?
