Another MF 230 question
/ Another MF 230 question #1
zenmek
Kentucky (in the bluegrass!)
Kioti LK3054, IH cub cadet 782, Grasshopper 721D2
Does anybody know where the hydraulic filter for this tractor ( '78' MF 230) is?? Is it a spin on cartridge, or just a screen, or perhaps a hidden filter element. Any help would be great!!
/ Another MF 230 question #2
I changed the hydraulics on my 230 and I'm pretty sure it was a screen underneath a retangular cover under the transmission, I don't have that tractor anymore and I'm not 100% sure but take a peek there. Cheers
Thanks for the quick post! I will tell the owner, hopefully he will be able to find it /w3tcompact/icons/grin.gif
/ Another MF 230 question #4
There is a plate under the rear end housing (Triangular with 3 bolts). You will have to drain the oil from the drain plug on the lower side of the same housing. Once you remove the cover you will see a cap that it will unscrew by gripping the tab. Inside there will be a strainer. You will need to remove the nut for the strainer to come down out of the hole. That is your filter for the 3-point hydraulic system
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
2020 Case TV370B (A64126)
2020 Case TV370B...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
Coleman Powermate Generator (A62613)
Coleman Powermate...
