Another Loader Problem
/ Another Loader Problem #1
kbforester
Pembroke, ME
International 460 Utility
Hi everyone,
I have a slight problem with my new (to me) old loader. Its a McCormick Power Loader #50 on an IH 460 utility. 12GPM hydraulic Pump. I had the cylinders rebuilt and all the hoses replaced by a professional, and just installed them. This is the first time the loader has been used in 20 years.
Problem: Lift arms and bucket come down extremely slowly.
Goods: Lift arm goes up very quickly, bucket goes up very quickly. As the lift arms and buckets go down, there is pretty good power. I can easily lift the front end of the tractor off the ground. Its just slow as molasses.
I have slightly more than the recommended hytrans oil in it. (10+ gallons). I haven't checked the oil filter yet, or messed around with the valves. Oil filter is brand new this winter. I haven't checked it yet because I hate loosing expensive oil. If someone thinks that could be it, I'll give it a shot. No significant leaks.
Could it be air in the lines? Valve adjustment?
-KB
/ Another Loader Problem #2
If you are using QD's, check the connection.
Check to see if any restrictor fitting were install by mistake.
Put loader hoses in a bucket and active the lever to see if flow is same in up lever and down lever.
Air in a hyd system will self purge by activation of the valve levers.
2018 FORD F-150 (A67714)
2018 FORD F-150...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2016 CHEVROLET TAHOE (A66091)
2016 CHEVROLET...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
2015 Hitachi Zaxis 210LC (A64911)
2015 Hitachi Zaxis...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
