Another Hydraulic Question Flow Control
/ Another Hydraulic Question Flow Control #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have been looking at flow divider control valves, i.e. 8 gpm , valve divides flow in 1/2 for motor or cylinder so they both move the same, Regardless of load.
Or some variation of that. My question is why is a valve like that not used on a FEL frame for lift. My thought is that the frame is stiff or strong enough so the hydraulic pressure imbalance is distributed by the frame,
If that is true then any frame supported device with two cylinders would not need a control valve like that.
When would you use a valve like that , for cylinders? Motors I can get.
/ Another Hydraulic Question Flow Control #2
Not needed, as pressure is equal, I would think.
/ Another Hydraulic Question Flow Control #3
Flow dividers work good for lifting loads with uneven pressures where synchronization is necessary (like lifting buildings or machinery with separate cyls), or tuning hyd motor speeds.....or splitting circuits for separate needs (power steering vs FEL controls).....
/ Another Hydraulic Question Flow Control #4
I worked on a machine that had eight legs all with separate cyls......they used 7 flow dividers that split flows 50/50 equally......
One hydraulic pump into one flow divider......then to two more on the next branches........then 4 more on the next banches to make 8 outlets going to 8 single acting lift cyls......all to make it lift perfectly straight up level.....
I get it. Thanks
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
