6sunset6
Veteran Member
- Joined
- May 6, 2007
- Messages
- 1,055
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have been looking at flow divider control valves, i.e. 8 gpm , valve divides flow in 1/2 for motor or cylinder so they both move the same, Regardless of load.
Or some variation of that. My question is why is a valve like that not used on a FEL frame for lift. My thought is that the frame is stiff or strong enough so the hydraulic pressure imbalance is distributed by the frame,
If that is true then any frame supported device with two cylinders would not need a control valve like that.
When would you use a valve like that , for cylinders? Motors I can get.
