Another Homebuilt Sub-soiler
/ Another Homebuilt Sub-soiler #21
gclark94560 said:
My wife thought it was part of a tree!:D
Um...A root is part of a tree...if it's a tree root. ;)
/ Another Homebuilt Sub-soiler #23
We have what we call bull nettle here that has roots about that size. The top part of the plant (all that is above ground) has stinging needles all over stalk, leaves, fruit, etc. Real painful if you brush up against it. Is that what you have?
/ Another Homebuilt Sub-soiler #24
They make these things called plows,,,been around for awhile,,about 300 dollars will get you one,,hard to make,,,than,,you just turn the dirt over,[they are called,,what else,,turning plowes],,,your yanmare will pull it no problem,,,thingy
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2021 Polaris General XP 4 1000 4x4 side by side (A60352)
2021 Polaris...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
