Another grapple valve vs. button thread
/ Another grapple valve vs. button thread #1
POC
Southern Indiana
Mahindra 3215 4x4
I know this has been gone over, and I searched, but I couldn't find a thread that answered just what I was wanting.
I'm going to put a grapple on the tractor, and need to add the additional function, just like everyone else...
That is all I'm looking to do right now, so as I see it, I can add a single handle, double acting w/ PB for about $120 (like Surplus Centers 9-6701 w/9-4895-B power beyond sleeve)
OR
I could put on a 12 VDC hydraulic solenoid for $110. (I see it says "D03 subplate mounting" does that mean I have to get the $47.50 subplate also?)
Other than adding in the wiring and button, do I have "apples to apples" here? Or are there other things?
Thanks for all the help guys,
Patrick
/ Another grapple valve vs. button thread #2
Yes, you NEED the subplate.
The MAIN difference between the two is that you cannot "feather" the solenoid valve, it is either ON or OFF. Now with the use of 1/4" hose to the grapple cylinder and possibly a flow restrictor, that may not be a big deal.
The solenoid can be mounted anywhere, the spool valve needs to be in reach...
Ok kennyd, maybe I'm missing somthing. I was wanting to make mine work like the guys with the buttons on their joysticks. Where the curl/uncurl action of the stick could be changed over to the open/close of the grapple. Is this solenoid valve not what I need for that?
Oh, I think I see now....the valve assembly that Hooked pointed out is more of a "selector switch" type, and what I had chosen was an actual control valve, but it is either open or closed. (Right?)
Thanks guys,
Patrick
/ Another grapple valve vs. button thread #6
If you look at the thread Selector Valve in this forum it will explain the functions of the valve I sugested.
Bill
/ Another grapple valve vs. button thread #7
Thanks guys,
Patrick
There are two type of solenoid valves...
One is commonly called a "diverter" or "electric diverter", and that is use to "divert" the curl/dump function to the grapple. There is a single momentary switch usually on the joystick.
The other type is a true independent valve,(commonly called a 3rd function valve on TBN) that mounts on a sublate, it will work completely independently of the FEL joystick, and they are operated by a 3-position (ON-OFF-ON) momentary switch usually on the joystick. You cannot "feather" this type of valve.
Both the valve are plumbed differently also...
Clear as MUD:D
Thanks kennyd, I looked at the "selector valve" thread and found all the info I was wanting.
I do understand now what you are saying though: The diverter lets you use the same stick motion but something else moves. The "true" valve is like adding another handled valve, but without the handle, a button instead.
Gottcha.
Patrick
/ Another grapple valve vs. button thread #9
Great!
A good diverter for just a grapple is the 9-5117 from the Surplus Center. The other option is the one being discussed in the other thread, but it's more complicated to hook up.
I wanted to keep some for expansion. But maybe I don't understand the way this works completely yet. If I have one more slot, I could still do something like tilt on the 3PH, right?
Patrick
/ Another grapple valve vs. button thread #11
Patrick
Yes, but you would have to run hoses from the loader (where the diverter would be mounted) to the rear...
/ Another grapple valve vs. button thread #12
POC,
I just remembered that user zimcocomp has a 9-5117 for sale that he couldn't use, he may make you a deal...Might try PM'ing him.
100 GALLON FUEL TANK (A68842)
100 GALLON FUEL...
1  JACK (A66091)
1 JACK (A66091)
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2014 Impala Limited Sedan (A66738)
2014 Impala...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
