Grapple Another Grapple-if ya'll can stand it!
   / Another Grapple-if ya'll can stand it! #1
RaytheOne
KY
JD 323D
Just picked up a new grapple yesterday. :D
Man, is it a monster! Top arms are 5/8" thick, everything else including the tines are 1/2". It's made by a company called LESCO. It was sitting on my local JD dealers lot. Had to change the couplers, as it had ag fittings on, and I needed flat face.
Got to try it out today, and it's a keeper!!!
   / Another Grapple-if ya'll can stand it! #2
Nice heavy grapple. How much does it weigh ? Looks tough.
Don't know about the weight, I've emailed LESCO to see what they tell me. Based on similar units, I bet it's close to 1000 pounds :eek:
Here are the specs they sent me:
Base Material:
Upper Jaw
The outer tines are 5/8" AR400 plate. The short inner tines are 1/2" AR400 material.
The cross tube is 3 x 3 x 3/8" tube.
Lower jaw
All of the tines on the lower jaw are from 1/2" AR400 material.
The balance of the material on the unit is A36 material.
All of the tines upper & lower are on 6 centers.
The cylinders are 3 bore x 8 stroke.
The cylinder rod is 1 1/2"
The approximate weight is 900 lbs.
Sure won't tear it up!!
   / Another Grapple-if ya'll can stand it! #6
Man I must be getting old , never thought I would be lusting over a grapple ! Is that a skid steer you mounted it on ?
Bdavis,
No, It's on my JD 110 TLB. Truth be told, it's plenty heavy for it, but I'm sure it will be fine for me. Worst case, I can always buy a bigger tractor!! :laughing:
   / Another Grapple-if ya'll can stand it! #8
i cant find lesco anywhere on the net
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
1831 (A51247)
1831 (A51247)
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
