Grapple Another Grapple-if ya'll can stand it!
   / Another Grapple-if ya'll can stand it! #1
RaytheOne
KY
JD 323D
Just picked up a new grapple yesterday. :D
Man, is it a monster! Top arms are 5/8" thick, everything else including the tines are 1/2". It's made by a company called LESCO. It was sitting on my local JD dealers lot. Had to change the couplers, as it had ag fittings on, and I needed flat face.
Got to try it out today, and it's a keeper!!!
   / Another Grapple-if ya'll can stand it! #2
Nice heavy grapple. How much does it weigh ? Looks tough.
Don't know about the weight, I've emailed LESCO to see what they tell me. Based on similar units, I bet it's close to 1000 pounds :eek:
Here are the specs they sent me:
Base Material:
Upper Jaw
The outer tines are 5/8" AR400 plate. The short inner tines are 1/2" AR400 material.
The cross tube is 3 x 3 x 3/8" tube.
Lower jaw
All of the tines on the lower jaw are from 1/2" AR400 material.
The balance of the material on the unit is A36 material.
All of the tines upper & lower are on 6 centers.
The cylinders are 3 bore x 8 stroke.
The cylinder rod is 1 1/2"
The approximate weight is 900 lbs.
Sure won't tear it up!!
   / Another Grapple-if ya'll can stand it! #6
Man I must be getting old , never thought I would be lusting over a grapple ! Is that a skid steer you mounted it on ?
Bdavis,
No, It's on my JD 110 TLB. Truth be told, it's plenty heavy for it, but I'm sure it will be fine for me. Worst case, I can always buy a bigger tractor!! :laughing:
   / Another Grapple-if ya'll can stand it! #8
i cant find lesco anywhere on the net
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A55852)
2005 Toyota Tundra...
