Oil & Fuel another fuel leak ?
/ another fuel leak ? #1
tonyw
NC
YM1401d
I have a 1401d which has recently developed a leak somewhere around the filter bowl. It appears to be coming from the shut-off switch, but there is also a little leakage at the fuel line connections to the bowl/filter. Could there be a seal gone bad at the shut-off? If so, would I have to replace the entire fuel shut-off assembly?
Also, this is probably a dumb question, but
would high temperatures have anything to do with the leaking? I recently built a small pole barn to store the tractor; it has hardly any ventilation--and it's been fairly hot here in recent weeks.
Thanks
Tonyw
/ another fuel leak ? #2
I doubt it is any hotter than the heat comming off the engine while working it.
Soundguy
<font color=blue>"would high temperatures have anything to do with the leaking? I recently built a small pole barn to store the tractor; it has hardly any ventilation--and it's been fairly hot here in recent weeks. "
/ another fuel leak ? #4
Also check the hoses in/out clamps and connections. I had one start to leak like that and it was just a loose hose clamp.
Jim
Thanks, everybody, for the help! I'll check it out tonight--and hopefully, stop the leak.
I'll get back with what I find.
Thanks again!
tony w
2011 Freightliner B2 School Bus (A61573)
2011 Freightliner...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
2003 Freightliner FL60 Ambulance (A61573)
2003 Freightliner...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
Caterpillar D6M Dozer Service and Parts Manuals (A63117)
Caterpillar D6M...
19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A61574)
19ft Sailboat w/...
